Question about JVC MX-D4T Shelf System
Turn off demo display - JVC MX-D4T Shelf System
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
How do I turn off demo mode for KitchenAid Model KEBS179BSS00
The following is from your Users Manual:
Demo Mode IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without heating elements or burners turning on. If this feature is activated, the oven will not work.
1. Press OPTIONS until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START to save the setting.
5. Press OFF to exit and display the time of day http://www.kitchenaid.com/digitalassets/KERS306BSS/Use%20and%20Care_EN.pdf
Feb 19, 2015 | KitchenAid Ovens
MY technics SH-DV290 AMPLIFIER is always in demo mode any ideas about turning it off.
Turning DEMO off
A demonstration of the display is shown if you have not set the clock.
You can reduce the power consumed in standby mode by turning the demonstration off.
While the unit is on:
Press and hold [-DEMO] until "NO DEMO" is
displayed.
Each time you press and hold the button:
NO DEMO (off)9DEMO (on)
The 'Demo' button is on the left hand side of the front panel.
Jan 25, 2011 | Technics SC-DV290 System
I have a cda-9883 alpine that is in demo how can i take it off demo and have it play normal?
hold down the function button until the display changes. you can then toggle things like dimmer ,aux, and demo by turning volume control. when you see demo push the play/pause button which will then allow you to turn it off by again turning the volume button. once its off press play/pause button which will allow you to toggle other functions. then hold function key down again to get back to main display(main display will eventually return on its own)
Dec 10, 2010 | Car Audio & Video
Cab't turn the bloody display mode off!!!
from what i understand it is called "demo mode".
To turn it off follow these steps:
1. Hold the Sel button till the display shows "demo" Then turn the volume knob until the display reads "demo off"!
Done :D
Hope this helped and if it didn't please give me more detail as to the problem...
Nov 23, 2010 | JVC KD-G140 Car CD Player
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
RTFM: Page 13:
"A demonstration of the display is shown if you have not set the
clock. You can reduce the power consumed in standby mode by turning the demonstration off.
Press and hold [–DEMO] until “NO DEMO” is
displayed.
NO DEMO (off) DEMO (on)
This is a 24-hour clock.
The example shows how to set the clock for 16:25 (4:25 p.m.).
1 Press [0/I] to turn the unit on.
Press [CLOCK/TIMER] to display “CLOCK”.
Each time you press the button:
CLOCK>>PLAY>>REC>>Original display
Within 5 seconds
Press [SET].
Press [TUNING (Up or Down)] to set the time.
The time display can be changed in one minute units by tapping
the buttons, and quickly by holding down the buttons.
Press [SET].
The time is set and the original display is restored."
Or under Troubleshooting Page 38:
"The display starts up even after the unit is turned off.
The demonstration feature (–DEMO) is on. Turn it off if it is not required."
If you need the manual go to
http://audio.manualsonline.com
register and get it for free.
Mar 25, 2010 | Technics SC-EH780 CD Shelf System
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
Stuck in demo mode. how do i change it?
Hello jayme84,
To cancel "DEMO" mode on the JVC:
Enter the PSM (personal settings mode) and turn DEMO off.
1) Press and hold "SEL" until the display changes.
2) Use the left/right rocker switch until "DEMO ON" is displayed.
3) Turn the volume knob to select "DEMO OFF".
4) Press "SEL" to exit.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
How do i set the time and remove the demo setting
Hello again johnworley6,
To set the time and/or cancel the demo mode, you need to enter "PSM" mode. Do this by pressing and holding the "sel" button for 4 seconds. Use the left/right rocker switch to select the item. Turn the "volume" knob up/down to change the item. Press "sel" again the exit PSM mode.
So to turn demo mode off: 1) Press and hold "sel". 2) Press right until "demo" is displayed. 3) Turn volume knob until "demo off" is displayed. 4) press "sel" again to exit PSM.
To set the time: 1) Press and hold "sel". 2) Press right until "CLOCK H" is displayed. 3) Turn volume knob until correct hour is set. 4) Press right until "CLOCK M" is displayed. 5) Turn volume knob until correct minutes are set. 6) Press "sel" to exit PSM.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | Car Audio & Video
20 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
