Question about Vivendi Universal Eragon for DS
Ds-how do you do multiplayer on eragon ds game
No idea what to do, should I use two dses, or a connecter cable HELP!!!
    Problem Solver:
  • 11 Answers
You cant use a connecter cable for ds you need to go to the multiplayer screen and have the other ds go to the ds download screen and you all should instantly connect up if not you need to make sure that the other person clicks on the little row that has the eragon name to it.
Posted on Feb 01, 2009
Can not get on the internet error code 051099-9
It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system.
Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step.
Trying to play online multiplayer with Nintendo DSi
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
Scroll over to the third page, and select "Internet."
Now choose "Connection Settings."
Click on "None" for "Connection 1."
Click on "Search for an Access Point."
The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Look for your wireless network.
What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
WEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
WPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
Other suggestions:
Make sure your router is set to broadcast in "b" or "mixed" mode. If your wireless router is transmitting in "N" only mode, you will need to switch it to "b/g" or "mixed" mode. For help accessing your router's settings, click here and select your router brand and model (if available). Most routers will have this setting in the "broadcast settings" menu.
Check for wireless interference, which can affect the signal strength to the Nintendo DS. To help minimize wireless interference, try the following:
Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Nintendo DS is an open area without objects or electronics blocking the signal.
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
Feb 01, 2011 | Nintendo DS Lite
My two girls have dsi,s how do the play with both ds,is on one game
hi there this should help ye out
Playing multiplayer with one Game Card:
Certain Nintendo DS games require only one player have a copy of the game to play multiplayer. Those without a copy of the game will need to download the game information from the player that has the game in their system.
This feature is available on games that have this icon on their packaging:
    To download game information:
  1. Insert the Game Card into the DS Game Card Slot on one system and slide it into place until it clicks. Turn the system on by pressing the POWER button.
  2. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears. If the host DS system's Startup Mode is set to
    • Automatic. The game's menu will appear.
    • Manual. Tap on the box for the Nintendo DS Card Slot using the stylus to start the game.
  3. Turn on the other Nintendo DS systems. For each of these systems, when the main menu appears, tap on the "DS Download Play" icon on the right, middle side of the screen to display list of available games.
  4. Tap the title of the game to begin the download.
  5. See the individual game's multiplayer instructions for additional game play information.
  • Playing multiplayer with multiple Game Cards
    Games that require each player to have a copy of the Game Card inserted into the Nintendo DS will feature this icon:
    multi_pak.gif Because each individual game title has its own method for setting up multiplayer games, you will need to consult the instruction manual for that particular title.
Jan 18, 2011 | Video Game Consoles & Games
I just got my ds and i have pokemon platinum version, but i have no idea how to connect my ds lite to my wii
Greetings,
You must have Pokemon Colosseum for the Wii for this to work.
  1. Start Pokemon Colosseum.
  2. Go to the regular multiplayer battle option.
  3. Press the option for wireless Ds play.
  4. Follow on screen instructions and start your Pokemon Platinum game when indicated.
Thank you for using FixYa! =) If I helped, please give me a rating.
Nov 25, 2010 | Nintendo DS Lite
How do you play multiplayer nintendo ds backyard baseball 09
it depends on the game option if it is capable of hosting multiplayer,using only a single card...if it does..activate it as a host and then let the other player download the game...play it enjoy
Mar 12, 2010 | Video Game Consoles & Games
I have guitar hero on 1 ds and decades on the other it says I can link them for multiplayer but setting one as host when I try to join the other doesnt detect any hosts
mqke sure your ds is close enough and try waiting about 1 min because it takes a while to connect...................................and if that doesnt work make sure those two different can play multiplayer together
Aug 03, 2009 | Nintendo DS Lite Console
How to i get to play two players on the Nintendo ds lite
You can play multiplayer games with a Nintendo DS Lite even if you don’t possess a copy of the game. If one of your friends has a multiplayer game card, they can use their Nintendo DS Lite as a host for the game session and you can join the multiplayer game.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Things You'll Need:
  • Nintendo DS Lite
    Using One Card to Host the Game
  1. Step 1 Look on the game’s packaging for the "Multiplayer" icon. If the game requires only one player to have a copy of the game, the icon will show two DS Lites: a DS Lite with a black screen transmitting waves to a DS Lite with a white screen. Below the two DS Lites is a range of numbers which indicates how many players the game can support.
  2. Step 2 Put the game card in the Nintendo DS Lite that is acting as the host for the multiplayer game session and start it up.
  3. Step 3 Have the other players turn on their systems. They will use the main menu screen to access the "DS Download Play" icon. They need to tap the icon to begin downloading the game information from the host DS Lite.
  4. Step 4 Begin playing when all of the systems have finished downloading the game information from the host.
  5. Multiple Cards for Multiple Players
  6. Step 1 Look at the "Multiplayer" icon. If every player in the game session needs a copy of the game in order to play, the icon will show two DS Lites, both with black screens, transmitting waves toward each other. A range of numbers is under this graphic and indicates how many people can play at one time.
  7. Step 2 Read the game's instruction manual on how to set up the game session. The steps required vary by company and sometimes by title within the same company.
*reposted from ehow.com
Jun 21, 2009 | Nintendo DS Lite Console
Nintendo ds lite 2 player
First, it depends on what game it is, NOT ALL GAMES have a DS Download feature.
If you are using a game with the DS Download feature, have the host DS set up the game, this would just be going through the multiplayer then DS Download function.
Next, make sure you both are in the same area (10 or so feet), basically if you can be in the DS Chat with your Local Wireless Connection, you can use your DS Download feature.
While the host DS is sending the signal, the other DS will have a feature in the main DS menu (If you have auto-start on, hold start while starting up the DS and going past the warning screen), it will be called DS Download Play.
Have the person receiving the signal click that option and their DS will search for any games being sent in the general area. Then all the person with the receiving DS has to do is click the icon and he/she will connect with the hosting DS.
The receiving DS will not keep the game on the hardrive on the DS, but he/she will be able to play with you; your best bet however is to get a second cartridge, but that part is your call.
Aug 20, 2008 | Nintendo DS Lite Console
Vivendi Universal Eragon for DS Logo
211 people viewed this question
Top Vivendi Universal Video Game Consoles & Games Experts
James Wishart
Ankit Chandel
Ankit Chandel
Bruce Meyer
Bruce Meyer
Level 1 Expert
Are you a Vivendi Universal Video Game Console and Game Expert? Answer questions, earn points and help others
