Question about York Sport & Outdoor - Others
York aspire circuit trainer display not working
Display need but does not come on. I think is a problem with the connection to the adapted. Perhaps lose wire on the circuit connection to adaptor. Can you advise please?
sandrew
  • 2961 Answers
SOURCE: Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Posted on Sep 10, 2008
  • 69 Answers
SOURCE: ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
Posted on Mar 27, 2009
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
hakimmadina_
  • 155 Answers
SOURCE: acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Posted on Feb 10, 2010
I fried the labelled R12 resistor beyond identification on the console circuit board of my York 360 HRC elliptical cross trainer. York service is no help. Need schematics on the circuit board or something...
you should be able to get a new R12 resistor at radio shack. be VERY careful when heating the solder up to remove/replace the resistor. Hope this helps!
Nov 16, 2013 | Exercise & Fitness
Solution for aspire 4745g when installing for ati driver it turn black?
An ATI adapter is a type of video adapter that is designed to be used on computers running Windows. If the adapter is disabled, you will not be able to connect any external monitors, video projectors or other similar devices to it, as your operating system won't be able to recognize it. Of the different ways you can enable this type of display adapter, one is through the "Display" manager in the Control Panel.
Click "Start." Click "Control Panel." Click "Display." Click "Change Display Settings." Click "Advanced Settings." Click the "Adapter" tab. Select the ATI adapter from the list on screen. Click "Properties." Click the "Driver" tab. Click "Enable" to enable the ATI adapter through the "Display" manager.
Or the driver you are installing is not compatible with your operating system or your computers hardware
Hope it helps
Jan 23, 2013 | Acer Aspire 5602WLMI Notebook
I need the users manual and guide for my acer aspire 3000 laptop
Windows 7 doesn't have drivers for much on that old of a computer
Dec 13, 2011 | Aspire Computers & Internet
My acer aspire 5610z series does not trun on even with the power cored followed rebooting trouble shooting nothing wrked i think it made it worse what do i do
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
Belt just runs at max speed automatically :(
Yes. Replace the speed sensor. In the unlikely event that the problem still is not solved replace the circuit board. J.
Jul 31, 2010 | York Yankees Bedding MLB Comforter
Computer display will not work
Check your 12v DC adapter and see if that has a good connection. Have the unit check to see if it has 12v DC coming out of it, just by using a multi meter that should confirm it has power or not. Now if the adapter is good then then you might have an issue with the lower board a possible open fuse or a defective computer board,but lets go with simple first.
May 15, 2010 | Schwinn 430 Elliptical Trainer
My tascam cd gt1 does not display anything when the power is turned on. i think that maybe it s the switch. completly dead. help
Test the power adapter to make sure that there is power at the plug (volt ohm meter). Try wiggling the plug while it is plugged into the unit with the power switch on. If it works intermittently it means that the solder joint for the power adapter jack has failed on the circuit board. If that isn't the problem it probably is the power switch that needs to be tested next. IF you aren't confident with disassembling the unit far enough to do the tests you will need to take it in for servicing. Let me know how you make out.
Jan 19, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Acer aspire 9300 black screen (display adapter)
Jun 21, 2009 | Acer Aspire 9300 Notebook
Sport & Outdoor - Others Logo
15 people viewed this question
Top York Sport & Outdoor - Others Experts
paulcarew
Shehu Pro
Shehu Pro
Brandon Berry
Brandon Berry
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
