Question about Ovens
Leisure alta cooker grill not working
The light for the grill does not come on
3 Suggested Answers
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
SOURCE: I have a BEko 'Leisure alta AL6ND' oven. The
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Posted on Mar 18, 2010
Testimonial: "Pretty much spot on. Thanks. "
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Hi my beko alta al6cdw cooker isn't getting hot the fan is working and its warm but not hot
assuming its the oven. check element or the thermocouple
Mar 23, 2015 | Ovens
My grill in my Tricity Bendix cooker is not working?
ISOLATE THE MAINS VOLTAGE TO THE COOKER AND GRILL, if it has a plug unplug it.
There is a regulator on the switch, you will need a tester, if this is working and continuity through the switch reducing as you increase or rotate the switch, that's working. Go to the back top a regulator is attached to the chassis of the cooker inspect for exterior damage, if not check continuity it should only conduct in one direction, and not to the chassis, if it is conducting in all , or opposite directions replace the component. You should be able to collect one from a small electrical repair shop.
Hope this is helpful.
Regards
John
Nov 01, 2014 | Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Instructions for lighting grill for Leisure Cooker GR6GV MKII
Have your flame next to the pilot light before turning on. Hold pilot knob in while lighting. Hold it in for about 30 seconds once it is lit. Then you can turn it to the on position and set the temp.
Feb 24, 2013 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
Dec 01, 2009 | Ovens
Leisure rangemaster 55 gas cooker
Nov 13, 2007 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
