Question about Car Audio & Video
I got the alpine Ive-w535hd and need to know what is the orange/white reverse wire is. Is it the dimmer ? Also what is the foot brake wire
3 Suggested Answers
  • 18 Answers
SOURCE: bypass iXA-W404
The 404 requires multiple signals from two separate wires to turn off the video block. Simply grounding one wire will not work. There are bypass modules that will send these signals to the head unit available on ebay. Just search alpine 404 bypass. Your other option is to use two toggle switches to simulate the parking brake and foot brake signals necessary to disable the video block.
Posted on Jun 30, 2010
  • 70 Answers
SOURCE: i have a VRVD630 i cant watch dvds because i dont
the parking brake wire just needs to go to a ground other than the ground for the deck and the orange reverse light wire you shouldn't have to worry about it if you turn on the deck and you still can't watch movies try hook it up to the illumination wire.
Posted on Jul 29, 2010
Wiring diagram from player to dc battery
Here is Alpine's wiring info:
Black: Ground
Yellow : 12v+ Constant
Red: 12v+ Switched
Blue: Electric Antenna Trigger
Blue/White: 12v+ Remote Trigger
Orange: Illumination
Orange/White: Dimmer
Brown: Mute
White: Left Front Speaker +
White/Black: Left Front Speaker -
Gray: Right Front Speaker +
Gray/Black: Right Front Speaker -
Green: Left Rear Speaker +
Green/Black: Left Rear Speaker -
Violet: Right Rear Speaker +
Violet/Black: Right Rear Speaker -
Dec 21, 2013 | Alpine TDA-7563 Cassette Player
IVE-W535HD
i have the same issue. if i find out later today ill respond back on here. calling best buy "geek squad"
Feb 24, 2013 | Alpine IVE-W535HD - 6.1" In-Dash Video...
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Need a wiring diagran for a alpine 7903
This is a pull-out deck, and should have the wiring schematic right on the chassis.
If it is illegible, you can use the standard wiring to wire it up as follows....
Yellow: Constant 12V Power
Red: Switched 12V Ignition Power
Black: Ground
Orange: Dimmer
Blue: Remote and/or Power Antenna turn on
Green/Black: Left Rear +
Green: Left Rear +
Purple/Black: Right Rear -
Purple: Right Rear +
White/Black: Left Front -
White: Left Front +
Grey/Black: Right Front -
Grey: Right Front +
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2010 | Alpine Car Audio & Video
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have...
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
Feb 04, 2010 | Car Audio & Video
I need the wiring dia. for alpine 8020
If the alpine 8020 is a deck(head unit) the wire diagram is as followed:
Red: Accessory
Yellow: Constant Power
Black: Ground
Orange to orange/white is a illumination or dimmer wire.
White: front left speakers
Grey: front left (white black and so on usually the negative on the speaker connections)
Purple rear left (purple black = neg)
Green: Rear Right
And if a video deck(light green is park brake)
(which is usually just a ground) so legally it needs to be on your park brake but can be grounded to make it work.
Speakers? (Terminals larger one is positive, smaller one is negative) Place capacitors on if needed to filter out and clear up bass
Hope this helps couldn't look uo what a alpine 8020 was..
Dec 10, 2009 | Alpine Car Audio & Video
Alpine cva-1005 ps2 not working while ebrake is up
just get 2 toggle switches and wire them up one to the foot brake wire and one to the ebrake wire ....then connect the foot brake wire to a 12 v+ and the ebrake wire to a ground ....then flip the switches as if you were stepping on the brake and pulling the ebrake then releasing the foot brake .... worked like a charm for me !
Jul 07, 2008 | Alpine CVA-1005 Car Video Player
Help
Depending on the vehicles wiring itself, Alpine uses the below color coding for its wiring:
yellow – constant +12v such as the positive battery terminal
red – switched 12v such as the accessory terminal of the IGN switch
black – ground which could be the chassis/body ground of the vehicle or the negative terminal of the battery
blue/white - remote trigger for add-ons such as a power amplifier
blue – will activate a power antenna (if present)
white and white/black - front left speaker + & -
grey and grey/black - front right speaker + & -
green and green/black - rear left speaker + & -
purple and purple/black - rear right speaker + & -
orange/white - reverse wire
white/pink - monitor control lead
pink/black - audio interrupt from mobile/cell phones
yellow/blue - parking brake
yellow/black - foot brake
To bypass, the yellow/blue must be triggered negative/grounded. Alternately, it may be easier to use an adapter such as a Peripheral PTR7 (http://peripheralelectronics.com/). In some regions, it is not allowed to operate this unit while vehicle is in motion.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck, kind regards and drive safe.
Jan 10, 2008 | Alpine CVA-1003 Car Video Player
Need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from the12volt.com
Best of Luck.
Oct 31, 2007 | Alpine CDM-7874 CD Player
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
