Question about Kenmore Sewing Machines
Kenmore sewing machine model 158.12370
Need manuel
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: Shark Euro-Pro Sewing Machine
contact euro at
EURO PRO OPERATING LLC
94 MAIN MILL STREET, DOOR 16
PLATTSBURGH, N.Y. 12901
1800-361-4639
THIS IS THE CORRECT ADDRESS AND COMPANY PHONE NUMBER HOPE THIS HELPS
Posted on Feb 23, 2008
mewms_14904
  • 1027 Answers
SOURCE: MANUEL FOR BROTHER XR-46 SEWING MACHINE
Manual for Brother XR-46c
Posted on Apr 13, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
lorizubie
SOURCE: A MANUEL FOR A SIMPLICITY SEWING MACHINE MODEL 237
Here is the direct link:
http://www.simplicityhomecare.com/manuals/
Posted on Jul 05, 2008
Free Kenmore sewing machine Manuel for model # 117-552
Check Sears. They carry a lot of Kenmore manuals. FWIW, the manuals are not free.
Oct 08, 2016 | Kenmore Sewing Machines
I NEED THE SEWING MANUEL FOR MODEL#158.13150.
Sears carries manuals for Kenmore machines. Or search the internet for:
Make + Model + the word "Manual"
Mar 22, 2016 | Sewing Machines
Can I get a free kenmore sewing machines owner's manual for model 148.280 or model 28
google search engine type in make and model follow promps for user manuels
Aug 25, 2015 | Kenmore Sewing Machines
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
Need a free manual/instructions Kenmore sewing machine #158.10691
Need a manuel for a Kenmore sewing machine model 158.10691
Sep 30, 2009 | Kenmore Sewing Machines
I need the manual for my Kenmore 385.12908
I was, also, looking for this manual. When I searched on Sears for the 908 model it is inferred as being within the model range of 12912-12916.
Using that information, I searched for:
"kenmore sewing machine manuals 385.12916"
on Google and the first result is the below link where there's an "open as pdf" button, I downloaded the manual, it's a very good digital copy.
Here's the better (and free) solution:
http://homeappliance.manualsonline.com/manuals/mfg/sears/38512916.html
Feb 27, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Manuel
I don't know of any free sites but there are a few if you google that question; they will charge you $10.00 It is a lot cheaper than Sears PartsDirect (800)366-778.
Bonnie
Sep 24, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
