Question about Refrigerators
How old is my frig
Model # 106.8566882
  • 198 Answers
Posted on Jan 24, 2009
Refrig making noiise
Ask them cover deforst heater
Aug 09, 2017 | Samsung Refrigerators
Fridge quit working a month ago, unplugged it and when i plugged it back in, it started working again. now it quits working all the time, but when i shut door firmly it starts up again and stays cold for a...
You don't say how old the frig is ... you cant have a frig run like this. On one day ... off the next ... slam the door and it works ... Either get a new frig of get this one repaired professionally. Probably best to get a new frig. I would guess minimum service call charge will be $250.00
Apr 05, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
My refrigerator is not working properly.. the freezer section is work fine.. but the other section is not getting cold...I bought this refigerator six months ago...the model is .. MCBR1010W
Your complaint is not unusual, except that you say the frig is only 6 mo. old. First, I suggest you call the manufacture for warranty service since the unit is still new. There are several items that could cause this problem. It usually will not help by playing with the controls for frig & freeze; the unit should work properly with the controls set at normal midrange for both frig and freez; changing the settings from normal cannot compensate for a mechanical problem. is the refrig in an enclosed space that cannot get good air circulation, or does this frig have the black grid coil in the back and you have the frig up against the rear wall so that no air can remove the heat from this coil ? Any other cause would require mechanical work within the frig components.
Aug 10, 2010 | Magic Chef Refrigerators
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
The fridg has a pool of water under the front door that keeps appearing even after we wipe it up. It has suddenly appeared today. It is a Silhouette 442 Frost Free model.
check drip pan under frig.remove ft bottom of frig under door/ck drip tray?full? old frig?-time to buy new one.could be working to hard(age,compressor going bad)will cause frig to sweat.producing water under it.hope this helps.:)
Nov 24, 2009 | Lands Phones
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool Frig
Is that everything in your freezer or just in the fridge. Is this a frostfree model. Often if defrost fails in a frost free model then it is unable to duct cold air to the refrigerator side of things. To fix- turn it off for a day or two.
Mar 16, 2008 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
