Question about Grundig GU26DVD 26 in. LCD TV/DVD Combo
Change picture setting from 50 hz to 60 hz - Grundig GU26DVD 26 in. LCD TV/DVD Combo
What is the frequency of Briggs and Stratton portable generator 30552-00 and if it is 60 hz and I wanna change it into 50 hz, Is it possible and how?
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
Feb 08, 2015 | Briggs Electrical Supplies
Generator low voltage
It could be several things but it sounds like it just running too slow. I would the engine rpms first. Depending if is a two pole or four pole and if your 60hz or 50 Hz on the needed unloaded rpms.
Example: 2 pole 60 hz. Engine needs to be running at 3600 rpm loaded and 3750 rpm unloaded; unless, it has a fuel saving mode.
A 4 pole 60 hz would running half this rpm. The 2 pole producing 50hz would have the engine running at 3000 rpm loaded (about 3100 rpm unloaded)
Now in order for the 50 hz system to produce the same output voltage it requires a different alternator than the 60 hz version; otherwords, You simply can't convert a 60 hz to 50 hz version without changing the alternator by changing the engine speed.
Dec 29, 2014 | Electrical Supplies
Hi the clock is set for 60 Hertz, What about countrys with 50 Hertz in voltaje?
50 Hz means the electric generator rotates 50 times per second.
And then electricity oscillates or reverses polarity 50 times per second.
Products rated for 60 Hz will not operate correctly with 50 Hz power.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 16, 2014 | Coralife Power Center DayNight Timer or...
Need to transform 120v power to 240v
Bad news:
UK has 50 Hz electricity, and appliances are rated for local power..
Any appliance made for US market is rated 60 Hz.
50 Hz and 60 Hz electricity are different.
Look at label on your mixer, and then look at labels on local appliances. You will see 50 cycles or 60 cycles. Rarely appliances are labeled 50-60 cycles.
http://www.worldstandards.eu/electricity.htm#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html#Hz
http://waterheatertimer.org/What-is-3-phase-electric.html#120-240
Hz Hertz or cycles or frequency is number of rotations the electric generator turns per second.
Some appliances are rated 50-60 cycles and will work worldwide.
However most appliances are rated 50 or rated 60 but not both.
60 cycle motor will not perform as expected when connected to 50 cycles. And might overheat.
Generally, most motors can be converted to different voltages by taking motor to motor shop (if you can find one these day)
However electronic controls cannot be converted between 120V and 230V, nor will 50 Hz electronics work with 60 Hz power
Sorry Sue.
Buy another mixer.
Business will benefit from surge of consumer buying.
Mar 28, 2013 | Hardware & Accessories
Power transformer if change from 50 hz to 60 clock
Is that a question or a statement?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-ICF-C212-Clock-Radios-manual/id/267ag023/t/2/
Considering a 9VDC battery keeps the clock alive when power is disconnected, I would guess the clock time is independent of line current frequency. Does anyone actually use motorized clock works anymore?
Feb 19, 2011 | Sony ICF-C212 Clock Radio
I have Distorted Picure Quility with any game i Play?
check that both tv and wii are on same Hz settings(50 or 60)
Apr 21, 2010 | Nintendo Wii Console
Change Hobart N-50 110 V / 60 Hz to 230 V / 50 Hz
You would need to provide the correct power to match the maching, or replace the rotor, stator, controls to match the higher voltage, and worm gears to correct the speed, from 60 to 50 Hz. Unless you don't mind it running slower. Cheaper to find one that matches your local spec..
Sep 25, 2009 | Hobart N50 Stand Mixer
I can´t play xbox 360. The xbox says change to 60 hz mode, and when i do, the picture gets messed up and won´t support 60 hz. 50 hz works fine though, but I can only use my xbox as a DVD...
is this on hd mode?, if so it needs to be on 1080i as 1080p will not work that high up. Also if you are not using the component lead then you should the picture is fantastic.
Jul 09, 2009 | Videoseven LTV30C 29.6 in. LCD Television
Change the TV setting from 50Hz to 60HZ
you will find the setting to 60Hz in the xbox menu; can't exactly remember where, but it is there as I use it for Gears of war.
Nov 24, 2008 | NEC MultiSync LCD1550VM 15" LCD Monitor
Grundig GU26DVD 26 in. LCD TV/DVD Combo Logo
88 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
