Question about Kocaso Sx9700
Calibrate my tablet keeps moving by itself how do i calibrate it?
Why does my tablet keep powering off when the battery says 82%
Battery is weak and not calibrating properly. Replace the battery and re calibrate unit as per the instructions that came with your unit.
Sep 15, 2017 | Tablets & eReaders
How to stop my samsung galaxy tab 3 from shutting off by itself
after it gets shut down does it power on again "If u try to on it" or the battry goes to 0% try to keep the tab on charging and pale it on a tabe and then operate it
Jul 23, 2014 | Samsung Galaxy Tab 101 Tablet...
How do I fix my tablet that won't fully charge?
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Jul 07, 2014 | Visual Land Connect 9" Android Tablet...
Calibration screen
There are forums on hacking the firmware on the device to stop the screen from calibrating...or you can reset it...
Jun 04, 2013 | Archos Arnova 10 4GB 4)
Etouch tablet
It looks like your tablet isn't calibrated correctly. Go to the settings and look for touch screen calibration.
May 22, 2013 | Tablets & eReaders
How to calibrate my tablet
You need to keep doing it till calibrated, happened to me but got it after a while.
Jan 15, 2012 | Archos 7 home tablet
I cannot find the touch screen calibration app...
Did you try looking in All Programs? Try looking in Settings or Properties. Maybe it doesn't have one, maybe it calibrates it itself
Jan 12, 2011 | Panasonic Toughbook 19 Touchscreen PC...
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Kocaso Sx9700 Logo
22 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
