Question about Mitsubishi HS-U781 S-VHS VCR
VCR eats tape when rewinding
I have the Mitsubishi HS-U781 VCR and it plays the tapes fine, but when I rewind without stopping the tape it won't rewind and just stops by itself and it's been eaten. If I stop the tape and then rewind it'll rewind it all the way to the beginning, which is great, but when I eject it's been eaten. Is there any way to fix this problem? Thanks, Levi
  • 2 more comments
  • socail100 Jan 01, 2008
    Emerson TV/VCR combo set chews up my VHS tapes !
    Went to the damn manufacturer web page and it was not working . Went to the 800 tele and the clerk was no help either.
    I think it is a small thing to fix only if one understood how the tapes wrork.
    Maybe a short video on this would help.
    Gerard_Sagliocca@yahoo.com
  • Anonymous Mar 28, 2009
    VCR chewing tapes is my problem too. Here's some helpful info I found on the web:
    http://www.cameratim.com/info/video-tape...
  • Anonymous Mar 25, 2014
    VCR stopped working (recording or playing tapes) Gives E2 error code
  • Anonymous Mar 29, 2014
    VCR tapes keep getting eaten
    Novelist:
    Champion:
  • 254 Answers
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
    Problem Solver:
  • 10 Answers
Quite often it is a cassette problem. The two winding reels run on plastic bases which often becomes very dry and the two reels do not run smoothly. Remove the outer casing and take the two tape reels and the tape out. Then apply a small amount of powdered graphite to the rubbing surfaces of the bottom casing. Reinstall the two reels, making sure to put the tapes in the correct positions around the tape posts, and then replace the outer casing. This often resolves the problem.
Posted on Jul 02, 2015
I have a Mitsubishi HS-U448 VCR. It plays my VHS tapes fine, but I can't get a blue screen when I turn it on. When I press 'play', the movie looks great. Once I hit 'stop', it'
It sounds like it is set to a TV station and since all the analogue stations have now gone you will only get static. Without a remote you wan't be able to switch it. I suggest you either shop around for a replacement (try Curry's partmaster) or use a universal one.
Jan 16, 2013 | Mitsubishi HS-U448 VCR
When i put in a tape, i get a squeeling sound, and the tape won't play.
The only way is to take the top off and watch what the tape is doing! You might even see some object inside which should not be there!
Jan 05, 2013 | Mitsubishi HS-U560 VHS VCR
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Tape will not play rewind or foward
in the vcr there are clutch disk pads in the gearing that wears down and or the belt is slipping or broke , it will need repair
Oct 11, 2008 | Mitsubishi HS-U447 VHS VCR
Tape Problem
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
VCR started eating tapes.
Let me know if you need more information as to where to purchase these parts.
Yes - There are cassettes available that are made out of clear plastic that allow you see what's happening. You can also trick the player into thinking there is a tape. There are sensors (mechanical & infrared sensors) that you can bypass.
- Jim
Jan 30, 2008 | Mitsubishi HS-U560 VHS VCR
Televison & Video Logo
1,198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
