Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Annoying beeping of the Kenmore refrigerator!!!
We have a Kenmore frig. (approx. 3 y.o.) freezer on top and basic, not fancy. It has decided, for whatever reason, to beep at us. This happened the first time when I left the door open too long. (We're in to 18 months of this!) Since then, it beeps (series of 3 high pitched beeps, pause for 10-15 seconds, then 3 more) for days on end, stops for some days, then resumes once again. Any suggestions on how to de-beep this basic opinionated refrigerator? I've tried shutting off the breaker for a period (sep. breaker), unplugging it for awhile...you name it, I've tried it. As far as I know. Thankfully, it's in the garage!! Help! I'm going nuts~
  • 1 more comment
  • MMQC Jan 24, 2009
    We do NOT have an icemaker in this and the beeping, a sequence of 3 annoying beeps, is NOT that of a fan motor. I'm sure open to any other suggestions, however. Thanks!
  • MMQC Jan 24, 2009
    Model #75952, 19.0 cu.ft. It might actually have a door alarm since leaving the door open too long was when it first went off. But it now just goes off when it feels like it, which is most of the time. And the door is shut!!! Looking forward to some helpful info~ Thanks!
  • MMQC Jan 25, 2009
    How about Model # 79575952401? Just where inside the frig if this is NOT the #? Appreciate your help~ Mary
  • 198 Answers
I don't believe this model has an alarm in it. The beep you hear maybe the evaporator fan motor, also if there is an icemaker in the frig be sure it is turned off
Posted on Jan 24, 2009
  • 6 more comments
  • tom weber Jan 24, 2009
    I will need a complete model # to look at the parts list for this frig. I looked at the basic number and could not see any door alarm, usually the door alarm will be on the front of the refrigerator.
    That is not the complete model # that is a stock # model number is located inside the refrigerator on small label
  • tom weber Jan 25, 2009
    If this is a Kenmore ref. there are 3 #'s preceeding the model number to determine who is the
    manufacturer. The model # number is usually located at the very top of the ref section, above the top shelf.either to the rigt or left depending on who made it.
    From other sources I found out this ref. is made by LG if you can remove the door switch ther should be more than 2 wires to the switch 1 of them is common 1 is for the light and the other is for the alarm, Remove 1 at a time to see which 1 dis connects the alarm. This may work, have not worked on any LG refrigerators of late.
    Does this ref has a digital display on the door? If so there is selection with a speaker on it. To mute the control you press on the speaker display to mute, press again to turn on.
  • cora Nov 27, 2011
    this model has a on the door to let you know that the door is open. solution close the door. hope this work. cora
  • cora Nov 27, 2011
    this model will beep when you open the door too long. so close the door and see what happen. how it work
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore top freezer frig
check your start relay on compressor. If that doesnt solve it then you need a new compressor. This is all based on the facts the you said the unit is running all the time
May 27, 2009 | Kenmore 63182 / 63184 Top Freezer...
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not working
is there frost building up in the freezer?mike
Nov 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
2,053 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
