1. If your mobile is on, power it off. 2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it. 3. Press Volume Down twice to designate Recovery mode. 4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark. 5. While holding down Power, press Volume Up. 6. Use the volume keys to scroll to "wipe data/ factory reset" and press Power to select it. 7. Scroll down to "Yes - erase all user data" and press Power to select it.
Don,t turn it over 2 then,LOL: It has developed a internal problem end is going into what is called the protect mode. You will have to take it in for repair.
You are overpowering the Amplifier and it is protecting itself until it cools down.
The reason for this is that the output from the IPOD is already pre-amplified. If it didn't shut down you would either blow the Amplifier or Speakers.
If you keep the volume turned down to a minimum on your IPOD and use the volume control on your theater system you should be OK but still don't turn the theater system to full output.
hold volume button down util the icon turns red then adjust volume with right arrow for up and left for down. when icon goes back to black it should have adjusted to the volume. Also the volume is listed numericly the higher the number the louder it gets.
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
• The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
• The volume level may be too low. In Windows, look at the volume
control icon on the taskbar. Fn-? Volume up Increases the sound volume.
Fn-? Volume down Decreases the sound volume.
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
