Question about Panasonic KX-TA824PK Phone
The intercom lights up but doesn't ring Panasonic KX-T7731
  • 8 Answers
SOURCE: How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Posted on Sep 16, 2007
  • 4 Answers
SOURCE: Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
Posted on Apr 09, 2008
Phonesmith
  • 113 Answers
SOURCE: Panasonic kx-t7731 phone.... How do you set the
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
Posted on Mar 18, 2010
cnavarro
  • 2460 Answers
With the phone idle, you keep pressint the * (or the TRANSFER key) until what you want is on the display. It uses one or the other key because the 77xx phone works on more than one system.
Carl
Posted on May 11, 2010
SOURCE: how set time for panasonic kx-t7731? thanks
This worked on mine:
Press Program, then 0
Make note of the numbers on the display (should read something like 100514 5 12:30PM).
Enter two digits for each in this order year month day.
Enter the same number that appeared on your display between the date and the time.
Enter the time.
Enter 0 for AM, 1 for PM
Press Store (phone should beep twice)
Press Program
Posted on May 14, 2010
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
How do I use the intercom function on a KX-T7731 phone??
Panasonic analog phones plug into analog KSU's and have extension numbers beginning with 101. In additon, you can dial 0 to reach the phone programmed as Operator, and it's usually extension 101.
With the intercom dial tone (press INTERCOM or pick up the handset or press SP PHONE) you can start dialing codes defined in your number plan. You can also program left side buttons to monitor are directly select other extensions or dial codes to page all idle speakers in a 77xx phone.
Note this is specific to TA series systems, but the operation is similar in all Panasonic models.
Carl
Apr 19, 2011 | Panasonic KX-T7731 Corded Phone
Remove night mode - phone not audibly ringing.
Pretend the phone is connected to a Panasonic TA series system. From extension 101 dial 781# on the intercom. It will put the system into day mode.
Carl
Apr 02, 2011 | Panasonic KX-T7731 Corded Phone
I can't get the msg light to go off on my Panasonic KX-T7731 even though there are no msg's
What happens when you dial 700-0 on the intercom?
7731's work on 18 different Panasonic models, but they were first delivered with the later TA series phone systems. You could press the MESSAGE key and look at the display to see where the message came from, but I don't think you can erase it on a 7731. So, just record the fact, then 700-0 and poof. All gone.
Carl
Oct 05, 2010 | Panasonic KX-T7731 Corded Phone
Do not know how to set the "ring over busy" feature on the panasonic KX-T7731
Panasonic calls that "call waiting". As answered previously, dial 7311# and 7321# on the intercom for a TA series system.
Carl
Aug 20, 2010 | Panasonic KX-T7731 Corded Phone
Hi, I'm working at a doctor's office where we have the KX-T7731. Whenever someone is speaking on line 1, we cannot hear the ringtone for the incoming calls on line 2 or 3. Since this is a doctor's...
Let's pretend that this is connected to the TA family of phone sytsems. It could be one of 18 different systems, but let's guess.
From the intercom, dial 7311# and 7321# That sets the call waiting on busy for both outside and inside calls and lets the phone "soft ring".
The real question is whether you should have programmed more than one phone to ring, but I'll leave that for another time.
Carl
Aug 16, 2010 | Panasonic KX-T7731 Corded Phone
I have a Panasonic KX-T7731 business phone system and I am trying to do the following" Program specific phones to be alerted with a tone for phone-to-phone intercom calls but to NOT be alerted when the...
In a TA series, the doorphone ringing is controlled by system programming in 700-702.
If you have a different system model, try the manual under Doorphone Ringing.
Carl
Sep 18, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX T 7731
From each of those 2 phones, on the intercom dial 7311# and 7321# The first tuns on call waiting CO and the second CW-Intercom. (0) cancels.
Carl
Jun 24, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX-TA824PK Phone Logo
50 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
