Question about DISH Network ViP 922
My 922 is shutting off and the only way to get it turned on is to unplug and then it shuts itself off again.
Our 50" plasma has a
The television shuts itself off and the light blinks in the front to protect itself when something is wrong with it. It will come back on a few times when unplugging and replugging but by doing that and not getting repairs done it has gone into a coma and will most likely not turn on again until it has been serviced. You can try leaving it unplugged for several days to see if you can get it to come back on.
Nov 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
TV shuts itself off
Mine does the same thing , too. I turn it on and off repeatedly , but nothing happens.I unplug it to see if it resets and nothing still .
Aug 02, 2008 | Mitsubishi WS-65908 TV
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
DISH Network ViP 922 Logo
46 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
