Question about Canon EOS-AE-1 35mm SLR Camera
Help with "B" setting
I am currently doing a light painting project for my photo class. I want to be able to keep the shutter open for as long as I want. I put the setting on "B" like all of the mauals tell me to but when I push the shutter release button the shutter closes. Please help!
    Problem Solver:
  • 9 Answers
You press the shutter once and that opens the shutter (you do your light painting) then you press the shutter a second time to close the shutter.
When you press the shutter the first time and look in the view finder it will be dark . this is because the mirror has locked its self up while doing the exposure (this is normal) Once you click the shutter a second time the mirror will flop down and you will be able to see threw the viewfinder again.
Posted on Mar 20, 2009
I set my camera to Manual setting but it takes blur photos. I am beginner and I don't know how to properly set the camera good for Manual setting. Any good setting for Manual? I will set that on m
The first number is the shutter speed and the second is the aperture. The two factors control the exposure.
The shutter speed (in this case 1.3 seconds) is how long the shutter is open to allow light to pass through the lens and strike the image sensor. The longer it's open the more light passes through. If there's not much light, like indoors or at night, the shutter needs to be open longer. A fast shutter speed can "freeze" motion, useful for things like sports. A slow shutter speed allows the subject to blur, useful for things like running water.
The aperture (in this case f/4.5) is a measure of how wide the lens opening is. The wider the opening the more light comes through. A smaller opening produces more depth of field.
The two work in tandem to achieve proper exposure. An oft-seen analogy is filling a bucket with water. You can turn the tap on all the way and fill it quickly, or just crack it open and let it take a long time filling drop by drop. Either way the bucket eventually fills up, but the two pictures may look very different.
I suggest you visit your local library and take a look at some introductory photography books. They will discuss the impact of shutter speed and aperture in much more detail than I can give here.
Aug 09, 2012 | Canon PowerShot S5 IS Digital Camera
I want to take star photos, how do I keep the apiture open (with a shutter cable) I tried but it doesnt stay open!
Set the mode dial to "M". Turn the command dial to set the shutter speed to "B". The bulb setting leaves the shutter open as long as the shutter button is held down, or fifteen seconds, whichever comes first. Unfortunately, that fifteen-second limit is much too short for good star trails. This is a limitation of the camera; there's nothing you can do about it.
This is a common problem with point&shoot cameras, even the advanced models. They're okay for 98% of the photographic situations you might encounter. But for the other 2% they either can't do it at all or make you go through hoops to do it. Just about every DSLR has a bulb mode that keeps the shutter open as long as you hold down the button (or better, yet, between two presses on a remote control unit so you don't even have to touch the camera), or until the batteries run out (and in those cases you can use auxiliary battery packs or just plug the camera into line power).
Apr 27, 2012 | Fuji FinePix S7000 Digital Camera
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
I have a nikon d40 when im about to take a photo i press the shutter down but it wont take a photo. mostly when im outside in the dark can you help
The camera may be set so it will only shoot when the camera is in focus, Like on Portrait or Landscape mode, and you cannot get the camera to lock in the focus so it won't shoot
Sep 23, 2010 | Cameras
Used to take great photos. Now lots are blurred.
Camera or hand shake are the most common cause of blurry photos, long exposure needs slower shutter speed, this is happened when your subject have inadequate light, and during this process, the camera sensor/shutter is open, causing the resulting photo to be blurry, because even a single movements of your camera or hand will cause the camera sensor to move, that causes a blurry capture. In order not to experience this, you have to be familiar with the setting of your camera, there are 3 important settings you have to understand: ISO Setting, Shutter Speed, and the Aperture Setting, they are related with each other. ISO Setting, is the sensitivity of your camera to light, meaning the higher the ISO, the more sensitive your camera in light, and the more sensitive, the faster your shutter speed. ISO scale from 100, 200, 400, and so on, depends on the cameras specs. Shutter speed, is the speed of the opening and closing of the camera's curtain( e.g. 1/30, 1/60 of a sec....and so on) and Aperture is the opening size of your lens focal points (the lower the f, the wider the opening: f1.4, f1.8, f2.0, f2.8, f3.5, f5.6, f8, f11, f16, f22, f32
I hope this will be helpful.
Jul 19, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Mavica FD95 and Sports Photography.
Basically you bought the wrong camera for your needs. The 95 can not do well under the conditions you describe. The ISO is fixed and to low for the amount of light you have available. The viewfinder begins to darken after the lens is wide open and the shutter speed is increased further. There are three possible cures. More light, not possible in your situation, faster lens or higher ISO, again not possible with your camera. Maybe you could convince them to play in the dayight. :)
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Canon EOS-AE-1 35mm SLR Camera Logo
126 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
