Question about Canon imageRUNNER 3225 Black and White Copier
ImageRUNNER 3235 DADF Jams
Will only feed a single sheet in the DADF. Second sheet will not load. If you put you finger against the trailing edge of the paper with even the slightest amount of pressure every sheet will feed fine. Replaced Sep pad and pickup & feed rollers with no change.
5 Suggested Answers
jeevan.m
  • 392 Answers
SOURCE: Canon lc 2060. REC. PAPER
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Posted on Jul 03, 2009
SOURCE: my 2270 jambs paper from tray one every time. I
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Posted on Sep 23, 2009
redzventures
  • 149 Answers
SOURCE: IR5570 jamming from paper deck #2 but having a
Check the duplex motor that feeds the reg roller shaft - in the front of the duplex unit. I found one that was loose, when I opened the front duplex cover and moved the motor, the screw fell out! The motor gear and drive gear were not touching. Good luck
Posted on Jan 30, 2010
edy_bubat
  • 289 Answers
SOURCE: we have a imagerunner 210s.
please to see the claws. they are 5 claws which pluged on exit unit.
if you open the cover exit you will see them.
the shape like as a tigers claw. but more like as triangle.
they are move by spring, you try to moving. what are they work well?
problem usually cause
- the spring was loose or (you can plug or replace the spring)
- the claws have broken or (you replace a new)
- the claws dirty by crust toner. (you can clean up by your finger or your claw)
good luck.
Posted on May 23, 2011
The document feeders jams with the first page. I tried to recreate the problem others have experienced. I took fresh paper and loaded the document feeder. It happened to me with the first page too. Any...
first clean the paper pick-up, feed and separation roller in the middle of DADF. If they are to smooth and worn out you need to change them.
Also check for foreign materials inside.
Hope that helps!
PS it also can be the problems with dadf pickup clutch.
Apr 29, 2011 | Canon imageRUNNER C3200 Copier
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    HP 2300 jams when duplexing multiple pages.
    try to replace the pickup roller and sepration pad (if ther are old)
    Mar 12, 2010 | HP Office Equipment & Supplies
    Paper not feeding properly
    Follow these steps to reload paper:
    1. Remove the paper and make sure it's not curled or wrinkled.
    2. Fan the stack to make sure the sheets are separated.
    3. Open the paper support and pull up the extension.
    4. Extend the output tray.
    5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
    6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
      You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
    7. Slide the edge guide to the edge of the paper, but not too tightly.
      Follow these guidelines when loading paper:
      • Do not load paper above the arrow on the edge guide.
      • If you're printing on both sides of the paper, try loading fewer sheets.
      • If it's wrinkled when it ejects, the paper may be damp or too thin.
      • Do not load paper with holes punched in it for insertion in a binder.
      • Load the printable side face-up. It's often brighter or whiter than the other side.
      • Load letterhead or preprinted paper top edge first.
      • If you experience paper feeding problems, try loading fewer sheets.
      • If you're using special paper, check the package for special loading instructions.
    Follow these steps to reload paper in the Automatic Document Feeder:
    2. Tap the originals on a flat surface to even the edges.
    3. Move the edge guides outward.
    4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
    5. Slide the edge guides against the originals.
    Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
    Epson Stylus photo 340 r printer paper jam when trying to print
    first, make sure you the paper correctly to avoid paper jam.
    Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
    if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
    Feb 09, 2010 | Epson Office Equipment & Supplies
    Epson stylus DX3800 All in one printer, scanner Unable to print
    Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
    Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Only 8 1/2 by 14 paper jamming at the DADF
    Does it feed sometimes, and just jams frequently, or every single page?
    Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
    Mar 16, 2009 | Office Equipment & Supplies
    HP PSC 1510 All in One paper jams and wil not feed properly.
    www.hp.com/support the people at HP have been very helpful to me try this and see what you get
    biigg53566@gmail.com
    Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
    Paper feed on Canon i 350n ink jet printer
    If the paper is lodged too far into the printer and can't be removed:
    Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    May 13, 2008 | Canon i350 InkJet Printer
    Canon imageRUNNER 3225 Black and White Copier Logo
    78 people viewed this question
    old marine
    old marine
