Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Screen shows staticy image on all components
Just randomly my mitsubishi tv started to show static. none of the components such as cable programming, game system, and dvd player could be used. they all showed the same static. there is also a loud crackling sound coming through the audio. we reset the audio/video, and nothing happened. any and all help would be much appreciated.
  • Mitsubishi Master
  • 8,617 Answers
Bad capacitors on the FMT pwb is what is most likely causeing it are the lines going sideways acrooss the screen, yet the menu appears normal.? If so its bad capacitors. You can get the V26 FMT repair kit at the following link which has the replacement capacitors and instructions on how to do the repair. You may also have an issue with the terminal 1 and terminal 2 pwb in that model as virtually every board within the chassis is plauged with Capacitors that fail. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 24, 2009
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
Play xbox sanyo tv
The best option is to try a different component cable and inspect both ports for any wear.
Alternatively, try the same cable on another TV if you have one near by.
Jul 01, 2017 | Sanyo DS20425 20" TV
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
I have a Mitsubishi VS-50705. It's a 50inch rear projection TV. The TV only allows me to switch between the ANT A and ANT B inputs, none of the others. When I plug in cable to either ANT A or ANT B nothing...
Hi con,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
Go to SET-UP in the MENU.
Then do a CHANNEL SCAN or AUTO PROGRAM SCAN.
You should be good to go..
Thanks for choosing FixYa.
John
Jan 06, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Audio is okay-blue screen will show on no input-audio can be heard but dark screen when any input has a signal. It is detected as 480 but no video,,,no raster on rf inputs Have electronics background can...
the problem is solved by expert electronic, because your tv have cpu program and need reconfiguration this program,
And other question is you check cable conexion
you check conexion
you check format/image programing (NTSC/PAL) if in the setup or menu have the best configuration, no all problem is the component electronic...
oh, you read manual step by step...
bye
Mar 07, 2010 | Mitsubishi WS-55807 TV
I can't get the tv to work
Make sure the cables work for the satellite tv, maybe there maight be a problem with them.
Apr 14, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
