If you have forgotten your WiFi security password, you should be able to reset your router via a tiny/recessed push switch. Then you will have to set it up again.
Disconnect the Knock Sensor Connector from the Knock Sensor. Unscrew the Knock Sensor from the engine block. Reverse order to tinstall.
The location will be on one side of the engine block or the other. I cannot tell you which side because you did not mention what engine your vehicle is equipped with.
NOTE: On many of the older Fords, the hole for the sensor actually goes all the way through the water jacket and antifreeze will come gushing out when you unscrew it.
Thank you for posting your question. To setup this wireless router on your network follow these instructions: Step 1. Plug in your D-link router to the wall outlet to power on. Step 2. Connect the ethernet cable on your DSL or Cable modem to the WAN PORT on the D-link router Step 3. Power on your DSL or Cable modem Step 4. Connect an Ethernet cable from your computer to LAN Port 1 on the D-link router (if you have a wireless card on your computer, you may be able to connect to the router without using the Ethernet cable) Step 5. Open Internet Explorer and type 192.168.0.1 then press Enter Step 6. You should be prompted for a username and password, type admin for the username and leave the password blank, hit OK Step 7. You will be brought to the Home Screen Step 8. Click the Run Wizard button Step 9. You will then input information regarding a new password, your time zone. Step 10. After that the Wizard will try to detect what type of internet connection you have with your Service Provider Step 11. If it cannot auto detect, you will be asked to select a type of connection Step 12. If you have a DSL modem, you will select PPPoE, if you have a cable modem, you will select Dynamic IP Address Step 13. If you selected PPPoE you will have to enter the username and password that your ISP has given to you for your connection. Step 14. You will then be taken to the Wireless Lan connection screen, you can change the SSID or leave it default. Also leave the Channel at 6 Step 15. You are then brought to the Encryption Screen. To enable encryption, select Enabled Step 16. Select your WEP encryption 64-bit or 128-bit Step 17. Enter the Hex key (up to 10 characters) Step 18. You setup is complete, you will be asked to retart the router through the Wizard, click restart
when you try to connect to the wireless network , do you see your network ? What is the operating system on your computer ? Is it windows XP ? If it is windows XP then try to use windows utility to connect to the wireless network ? Click here for more instructions about the wireless network
you can download all the software from you mobile makers site . if you go to samsung web site search your phone you will bbe able to download it to your desctop and run it form there to install.
Pls eloborate your issue
