Question about Brother Mfc-9125cn Multifunction Color Laser Printer
Loud grinding noise when printing - Brother Mfc-9125cn Multifunction Color Laser Printer
What causes a loud grinding noise when I print?
Howell310,
Can you provide the model of the Dell Printer you have that is making a loud grinding noise. I can the search for resolutions to this issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 27, 2016 | Dell Office Equipment & Supplies
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Printer makes grinding noise and not printing
sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
Brother Mfc-9125cn Multifunction Color Laser Printer Logo
127 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
