Question about Audiovox Home Security
Audiovox model AOC-52 stopped working in motor home
Remote control won't turn on radio
Have been to the audiovox home Page type in your model number and go to trouble shooting there you will find how to program the remote back to factory settings
Nov 16, 2012 | Audiovox Xpress R XM Satellite Radio...
I have an Audiovox TV Model no. TV92722. There is no Channel 52, 53, and 54 when cable was installed. When it is in channel auto search, it stopped searching. But if manually searching for channels 55 to...
first, make sure the TV in in American Cable mode (ntsc). next do this, menu... tuner... cable... scan... the reason maybe the TV is on TV air mode; but now is receiving cable. from the antenna coax cable. . another reason is that many cableco's now use Switched Digital Video ( a more robust setup) that now requires the Digital Tuning Adapter... also to help prevent free-loading. a last possibility is your (old) TV does Not work on the new cable. A new TV usually cures this ...!
Oct 26, 2017 | Audiovox Televison & Video
Can not get a link to any satellite channels; everything else works; need an owners manual
Not sure if this is exactly your model but worth a try:
http://www.xmradio.com/pdf/hardware_support/audiovox/Xpress_Rcvr128-7454C_8-01-06.pdf
Oct 13, 2010 | Audiovox Xpress Satellite Radio Receiver...
I put a new motor in my 88 trooper. After the engine swap the cruise stopped working. I have power,and vacum. I see a loose blue wire coming from the black canister. Any ideas?
check to make sure the tach sensor wire for the audiovox cruise control is connected, and also possibly speed sensor wire .... But I suspect the tach wire was left hanging after the motor replace
Apr 17, 2009 | Car Audio & Video
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
I can't get my audiovox XCS9 XM Radio to work in my home
Check to see if youre cable is plugged into the line out jack. If that is not the problem you may have a defective cable or home adapter
Aug 23, 2008 | Audiovox XCS9 XM Radio Receiver
Audiovox DVD Home Theatre system - STS93
I use a pocket knife to help mine open and then push it close. As far as i can tell the tray for this model was ill designed coupled with a crappy motor that may go out with out reason or warning...
Aug 20, 2008 | Audiovox 150W DVD Home Theater System -...
Home Security Logo
192 people viewed this question
Top Audiovox Home Security Experts
Lawrence Oravetz
Are you an Audiovox Home Security Expert? Answer questions, earn points and help others
