Question about RCA RCD123 Cassette/CD Boombox
RCA boombox cd player won't play any more what can cause that?
RCA rcd 134 cd won't read cds we have cleaned it but it do anything. Everything else works on it.
5 Suggested Answers
ongolo
  • 11 Answers
SOURCE: Boombox won't play most CDs
Hi there , heres a simple case of the recording format on the cds , its likely that your daughter's cds are recorded on a computer in a format probably mp3 or higher speed thats not compartible with your boom box . The solution to this is to record your cds in Normal format , and they will surely play !
Posted on Mar 29, 2007
SOURCE: How to get in to clean the lens for RP-9316 Boombox
I had the same issue. Over time, the cd player quit palying at all. The unit would try to read the cd but couldn't and then skip to the next cd.
- I took fairlane's advice and put a cd in and listened for the ticking sound to indicate that the laser was trying to read the cd. I also looked inside through the top "vent" area to be sure the cd was actually spinning. It was spinning and I heard what I thought I was "ticking" sound so I guessed that the laser needed to be cleaned.
- I took off the 6 side panel screws on the right side of the entire unit and loosened the screw on the backside off the unit about halfway down from the top that also held the side panel on.
- I then removed the side panel.
- I then removed the 2 screws on the top side of the other side panel and the screw in the top center back of the top panel and was able to remove the top cover that is over the unit. The top cover is "pressure fitted" in so be careful as you try to remove it, using a little wiggle at a time, but it does comes off.
- Once you have the top off, there is a screw in the center of the plate that holds the tray for the cd's. Remove the screw and you will able to lift and spin the tray to have clear access to the laser
that needs to be cleaned. (Note the position of the numbers on the tray so you put it back the right way.)
- The laser is a little "glassy" looking thing about the size of the head of the q-tip.
- I used the q-tip with 70% isopropol alcohol and rubbed it over and around the laser as best I could. I repeated the procedure 2-3 times and the used compressed air to dry it off.
- I put everything back in place in the reverse order I took it off, based on what's in the above steps.
- Remember, the top will fit in with pressure so don't get anxious as you try to get it in the right position.
The cd's actually play again.
I hope this will help someone.
Posted on Jan 03, 2009
SOURCE: cd player is not working
?: Does the cd spins? If it does the optical eye that reads the cd could be dirty. Clean the eye with cd lens cleaner. If the cd is not spinning the motor could be bad. Also some cd players can't read certain disks because of the density of the disk. Make sure you read the manual to see what cds are compatible with your boombox. I hope these solutions were helpful.
Good Luck
George
Posted on Mar 02, 2009
  • 4234 Answers
SOURCE: My RCA RCD160 Radio/CD playder will not play CDs.
Try cleaning the lens in the CD player with a cotton swab and alcohol. If that does not resolve the problem, it is likely that the optics are defective and need to be replaced.
Dan
Posted on Mar 25, 2009
RCA RP-7979 - what is the small black piece that the CD snaps onto inside CD player?
You probably are missing the hub. Your CDs won't play without it
Jun 25, 2013 | RCA RP-9316 Boombox
Why does my cd player on my Radio/Cassette/CD boombox keeps reading ncd on all my CD's even on my disk cleaner cd?
The laser assembly is not reading the disc, as the laser ages it becomes weaker until it can no longer scan the disc and can not play, you have done everything that I would have recommended, at this stage it is far cheaper to replace the boombox than replace the laser pickup assembly.
Mar 28, 2012 | RCA RCD147 CD Boombox
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Jan 19, 2012 | Panasonic Audio Players & Recorders
Dan
Mar 25, 2009 | RCA RCD160 Radio/CD Boombox
Cd player is not working. One day it was working and next day it wasn't. I guess a button was pushed and now we can't figure out. Cd player will not read or play cds
Good Luck
George
Mar 01, 2009 | RCA Audio Players & Recorders
Music on CD sounds like it's vibrating
Locate your CD reader bulb just inside the tray. Clean it good with rubbing alcohol. It still has a chance that it can be saved.Beacuse it is still reading. If it stops reading, you will have to buy a new player . Also if cleaning it does not works.
Jan 11, 2009 | Sony RCD-W500C 5-Disc CD Recorder
CD Player Does Not Read CDs
Hi As you describe the problem, there are three likely possiblities, either the laser lense is dirty, the laser is beginning to fail, or there is a dead spot developing in the spin motor. Cleaning is the first step, and the least expensive...If you have some electronics experience, they are not difficult to clean, but you must expose the laser to do it, and I don't want to advise someone to do that, and forget to unplug the unit. It's free laser eye surgery, but I doubt you would be happy with the results. I would advise you to call around to local repair shops, and see what they charge to check it out and/or clean it, and then descide if it is worth proceeding. Hopr this helps, good luck!
Apr 13, 2007 | Philips 3-Disc Changer FW320C Cassette/CD...
Mar 26, 2007 | Philips AZ1303 Radio/CD Boombox
CD Player Issue
the system has problems reading burned CD's u cant fix it or anything windman
Jan 30, 2006 | RCA RP-9316 Boombox
RCA RCD123 Cassette/CD Boombox Logo
340 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
