Question about Soleus Air 70 Pint DP1 Dehumidifier
Soleus 70 pint dehumidifier will not start
Model sgdeh701a
raymondguy
  • 3 Answers
SOURCE: Soleus 40 pint dehumidifier... used for 3 years,
Check to see if the styrofoam is still in the lever of the shut off arm. It's atop the water reservoir. If there is nothing there it will not float causing the arm not to shut off.
Posted on Dec 05, 2009
  • 117 Answers
SOURCE: My Soleus Dehumidifer is not dehumidifying
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Posted on Jan 06, 2010
  • 117 Answers
SOURCE: I need a repair part
contact@soleusair.com
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: Soleus CFM-25 dehumidifier fan works,
If everything you are saying is true then refrigeration system has lost the freon charge..
for the charge to be lost there must be a leak also...
Till you find the leak and recharge the unit it will cost more then a new one...
heatman101
Posted on Dec 14, 2010
heatman101
  • 43501 Answers
SOURCE: My 40 pint Soleus dehumidifier doesn't pull any
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
Jun 03, 2015 | Soleus Air DP2-70-03 aka SG-DEH-70-2...
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
Soleusair 45 pint dehumidifier won't drain through hose
We have a Soleus Air 30 pint that initially would not drain through the hose that we attached and dropped down the sump drain. After reading here, I tried tilting it back about a quarter inch and that didn't fix the problem. Then I tilted it forward a quarter inch (I put a couple pieces of cardboard under the back wheels) and it started draining properly. It is doing a marvelous job of dehumidifying the house now!
Mar 04, 2012 | Dehumidifiers
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
My 40 pint Soleus dehumidifier doesn't pull any water into the tank even though the fan blows normal.
heatman101
Jun 18, 2010 | Soleus CFM-40 Dehumidifier
Soleus Air 70 Pint DP1 Dehumidifier Logo
Top Soleus Dehumidifiers Experts
Gil Shultz
Terry Hair
 Russ Hill
Russ Hill
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
