Question about KitchenAid KGRA806PSS Gas Kitchen Range
Error code 0100 - KitchenAid KGRA806PSS Gas Kitchen Range
I can E000400-0100
Power on error code E400.
E400-0100
can occur if the Communication Cables on the rear of the scanner are loose or improperly connected. Re-seat all the cables on the rear of the scanner.The problem is with the adf. You can try to reseat the connectors on the adf controler PCB. Only do this with the copier turned OFF. If that does not work you will most likely need to replace the adf PCB.
to see the location of PCB click the link below:
http://fexya.blogspot.com/2016/06/canon-ir-c5185-error-code-ir5075n-e400.html
this will help.hanks
May 16, 2015 | Canon Office Equipment & Supplies
Gta4 cheat codes ps3
Enter one of the following codes during game play. A small box will appear to confirm correct code entry.
Code: Result:
Circle, X, Circle, Square, Triangle, L1, R1, L2, R2. Any truck with trailer
R1, L2, R2, L1, Up, Down, Up, Down, Up, Down. Cop
Triangle, Left, Right, Circle, X, Up, Down. Drink beer
R1(2), L1, R2, Triangle, Left, Right, Square. Fly in the air
R1, L1, L2, Square, R2, Left, Right, Left, Right. Health
X, Circle, Circle, R1, Square, L1, Triangle. Helicopter
Up, Down, L2, R1, X, L1(2), Right, Left, Up. Listen to Back On My Grizzy in car
R2(2), Up, Circle, L1, L2, Down, Triangle, R1, Right(2). Listen to Crank That SouljaBoy in car
Circle, Right, Circle, Right, Left, Square, Triangle, Up. Lock wanted level
Up, Down, L1, L2, Left, Right, R1, R2, Square. Money
L1, Circle, X, R1, L2, R2, Square, Triangle, Triangle, X. Monster Truck
R1, Circle(2), L2, R2, Triangle, X, L1, Right. Never die
Press X, Circle, Triangle, Up, Down, Left, Right, Circle(2) while in an area with a lot of space. Private jet with pilot
R1(2), Left, Right, L2, Square, Triangle, L1, Circle. Run quickly
L1, R1, X, Circle, Triangle, X, R1, Square. Semi truck with trailer
R1, Circle, L1, X, Left, Down, L2, Up. Smoke
Up, Down, Left, Right, Circle(2), Left, Right. Tank
Square, Circle, X(3), Triangle, Square, Circle(3). Unlimited bullets
Square, Left, R2, Down(2), L1, Up, Circle. Unlimited money
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up, Right(2) Weapon tier 3
R1, L2, R2, L1, Up, Down, Left, Right, Up. Weapons tier 1
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up. Weapons tier 2
Cell Phone Passwords
At any time during the game, pull out Niko's phone and dial these numbers for the desired effect.
Password: Result:
468-555-0100 Change weather
486-555-0150 Get a different selection of weapons
486-555-0100 Get a selection of weapons
267-555-0150 Raise wanted level
267-555-0100 Remove wanted level
362-555-0100 Restore armour
482-555-0100 Restore health
227-555-0142 Spawn a Cognoscenti
227-555-0175 Spawn a Comet
938-555-0100 Spawn a Jetmax
625-555-0150 Spawn a Sanchez
227-555-0168 Spawn a SuperGT
227-555-0147 Spawn a Turismo
359-555-0100 Spawn an Annihiliator
227-555-0100 Spawn an FIB Buffalo
625-555-0100 Spawn an NRG-900
Jun 04, 2014 | Video Game Consoles & Games
SCX4824FN driver
Fixya doesn't have any drivers for any device, the only place to get the software is at the manufacturers support site, if they don't have the needed drivers to use Linux then it likely doesn't exist.
Feb 10, 2012 | Samsung SCX4824FN Mono All-in-One Laser...
How do i reser error code e005 0100
How to clear fixing web counter after replacement of fixing web roller: E005 Error Code
[ Case in the field ] Field Remedy
Execute the following service mode items.
1. COPIER > COUNTER > MISC > FIX-WEB
2. COPIER > COUNTER > DRBL-1 > FX-WEB
Sep 04, 2009 | Canon CLC 1180 Copier
I am getting error code e005 0100 how do i reset
E005 Error code details
  Main Cause The fixing web has been taken up. The fixing web length sensor (PS45) is faulty. The DC controller PCB is faulty.
Mode of Detection
 0000 The length of fixing web that has been taken up is in excess of the specified length.
Caution After replacing the fixing web, be sure to reset the two web counters in service mode: COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FX-WEB.
Xbox360 gta4 cheat codes
i know ALOT of cheats for grand theif auto 4 for the 360 here they are :
    Full health and armor Dial "3625550100" on the cell phone. If you enter this code while in a vehicle, it will also repair it. Note: This phone number translates to "DOC-555-0100". This code prevents the "Cleaned The Mean Streets", "Finish Him", "One Man Army", and "Walk Free" achievements from being earned.
    Full health, armor, and ammunition Dial "4825550100" on the cell phone. If you enter this code while in a vehicle, it will also repair it. Note: This phone number translates to "GTA-555-0100". This code prevents the "Cleaned The Mean Streets" achievement from being earned.
    Weapons tier 1 Dial "4865550100" on the cell phone. This will unlock the baseball bat, handgun, shotgun, MP5, M4, sniper rifle, RPG, and grenades. Note: This phone number translates to "GUN-555-0150". This code prevents the "Cleaned The Mean Streets" achievement from being earned.
    Weapons tier 2 Dial "4865550150" on the cell phone. This will unlock the knife, Molotov cocktails, handgun, shotgun, Uzi, AK47, sniper rifle, and RPG. Note: This phone number translates to "GUN-555-0100". This code prevents the "Cleaned The Mean Streets" achievement from being earned.
    Remove Niko's wanted level Dial "2675550100" on the cell phone. Note: This phone number translates to "COP-555-0100". This code prevents the "One Man Army" and "Walk Free" achievements from being earned.
    Add one star to Niko's wanted level Dial "2675550150" on the cell phone. Note: This phone number translates to "COP-555-0150".
    Spawn Annihilator police helicopter Dial "3595550100" on the cell phone. The Annihilator is armed with rockets. Note: This phone number translates to "FLY-555-0100". This code prevents the "One Man Army" and "Walk Free" achievements from being earned.
    Spawn Cognoscenti Dial "2275550142" on the cell phone. Note: This phone number translates to "CAR-555-0142".
    Spawn Comet Dial "2275550175" on the cell phone. Note: This phone number translates to "CAR-555-0175".
    Spawn FBI Buffalo Dial "2275550100" on the cell phone. Note: This phone number translates to "CAR-555-0100".
    Spawn Jetmax Dial "9385550100" on the cell phone. Note: This phone number translates to "WET-555-0100".
    Spawn NRG-900 Dial "6255550100" on the cell phone. Note: This phone number translates to "MBK-555-0100".
    Spawn Sanchez Dial "6255550150" on the cell phone. Note: This phone number translates to "MBK-555-0150".
    Spawn SuperGT Dial "2275550168" on the cell phone. Note: This phone number translates to "CAR-555-0168".
    Spawn Turismo Dial "2275550147" on the cell phone. Note: This phone number translates to "CAR-555-0147".
    Change weather and brightness Dial "4685550100" on the cell phone. Note: This phone number translates to "HOT-555-0100".
The following codes require "The Lost And Damned" bonus downloadable content:
    Spawn Burrito Dial "8265550150" on the cell phone.
    Spawn Double T bike Dial "2455550125" on the cell phone.
    Spawn Hakuchou bike Dial "2455550199" on the cell phone.
    Spawn Hexer bike Dial "2455550150" on the cell phone.
    Spawn Innovation bike Dial "2455550100" on the cell phone.
    Spawn Slamvan Dial "8265550100" on the cell phone.
Mar 29, 2009 | Video Game Consoles & Games
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Canon 1140 E005 and 0100 error
off the top of my head a 0100 error code for a canon usualy relates to network cards. try removing the card and powering up without it in, should help determine if thats the problem. Hope this helps Cops Pete@wedotoners.com
Oct 09, 2007 | Canon CLC 1140 Copier
Canon 1140 trouble shooting
Been a while ago on the Canon but if memory serves me Error E005 means the cleaning web has run out. Needs replacing and resetting (replace then code 28 i think).
Oct 09, 2007 | Office Equipment & Supplies
KitchenAid KGRA806PSS Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
