Question about Franklin Electric 5800060100 Pumptec-Plus Motor Protection Device 230v 1 Phase 1/2-5 HP
Franklin Pumptec Plus will not reset after triping out
Pressure drops as soon wand trigger is pressed
I would expect it especially if the tip is not on the wand or open to far. It is possible the pump is failing. How much is the pressure dropping, a few pounds I would expect but I am not familiar with that unit.
Sep 18, 2013 | Pumptec Series 205V - 150/M77 Pump - 230...
WERE CAN I FIND MANUALS FOR FRANKIN SPELLMASTER PLUS MODELS DC120&SA103
Many manuals are available from the Franklin manual page.
You'll find the SA-103 manual there, but I don't see one for the DC-120 at this time.
May 30, 2011 | Franklin Office Equipment & Supplies
The on off switch in my Franklin Wordmaster only works intermittently. I would like to clean the contact that this makes work but cannot take the device apart. I have removed the 2 screws in the rear but...
take a sharp cutter blade and try to separate the two two from the joint ...u have to put a bit effort as there are plastic locks to hold the two together
Aug 29, 2010 | Franklin Spelling Ace SA-206S
Where can I gey a instruction manual for a
All the available manuals are available here. If you cannot find the exact model, try a similar model. Most models under one category share the same functions.
Dec 12, 2009 | Franklin Office Equipment & Supplies
Franklin BIB-1450 cannot turn on.
Turns out the batteries that I tried were dead. Bought new batteries and installed them. The Franklin BIB-1450 now works. Yay!
Jul 31, 2009 | Franklin BIB-1450
Forgot password
Unfortunately, you have to reset the unit if you forget the password...here is the link to the user's manual....see page 15.
http://66.179.52.179/franklin/data/public/manuals/sa-206s/sa-206senglish.pdf
Dec 25, 2008 | Franklin Spelling Ace SA-206S
PlanPlus Constantly Crashes Outlook
I was having the same problem. I launched outlook in safe mode. start run outlook /safe. After starting outlook went to the help menu and selected the about microsoft outlook. Click the disabled addons button, enable the the planplus plugin. Close outlook and open it normally. this fixed this issue for me.
Sep 18, 2008 | Franklin Covey PlanPlus 4.0 for Windows XP...
Trial version Vs. Registered Version
I had a similar problem and found out it was a conflict with "google desktop". If you are running that program, try uninstalling it and see if it makes any difference.
Mar 10, 2008 | Franklin Covey PlanPlus 4.0 for Windows XP...
Franklin Electric 5800060100 Pumptec-Plus Motor Protection Device 230v 1 Phase 1/2-5 HP Logo
91 people viewed this question
Top Franklin Electric Plumbing Experts
Paul Carew
Tom Chichester
Are you a Franklin Electric Plumbing Expert? Answer questions, earn points and help others
