Question about 1996 Pickup Short Bed Xe Egr Valve Vacuum Switch
1996 nissan pickup battery wont stay charged and alternator and battery are new. what could the problem be?
Battery and alternator are new. but battery wont stay charged. sometimes it will start and sometimes not. If I run vehicle with any accessory like heater , lights, radio, it dies quickly. could this be a dead spot in the starter?? OR What ???
    Master:
  • 448 Answers
The battery is really just for providing power when the vehicle isn't running, and providing power needed for the starter to start the engine. The rest of the time the alternator is charging the battery and providing the power for the vehicle. You may have a short somewhere that is draining the battery when the vehicle is sitting and not running. If the vehicle does not run long after charging the battery, then there's a problem with the alternator. You can actually run the car without the battery, provided the engine is running and the alternator is working properly.
Posted on Dec 10, 2014
Battery dead
Your alternator isn't charging your battery so your car is draining the battery. Have auto zone test your alternator
Nov 08, 2013 | Nissan Rogue Cars & Trucks
My 1996 Nissan Maxima's Alternator
Just because they're new doesn't mean that they work. I would find an auto parts store that does free electrical system checks before spending a dime elsewhere. I've gone through 4 batteries in 3 years because of bad products. And have most recently had to replace a brand new alternator because it, too, was defective.
Aug 07, 2012 | 1996 Nissan Maxima
New baterry and alternator it crunk but wont start what is the problem
If battery and alternator are good is starter solenoid pulling in? it may be that whilst you have a new battery it may require charging new doesn't mean fully charged, batt may have been on shelf for awhile
May 01, 2012 | 1986 Nissan Pickup 4WD 1986
Altinator is good tested fine battery new still not charging ?
If your alternator tested good and the battery is good, then the only other thing that would be involved is the battery cables. Did you clean the battery cables and battery terminals?
Aug 17, 2011 | 1996 Nissan Pickup
1996 chevy s10 pickup brand new motor new everything but wont start thought it was a timing problem..fixed it wondering what it could be? Maybe something with the distributor but not sure where to find a...
Battery light indicates alternator failure. If you have a voltmeter, check voltage at battery with engine running. Should be at least 14 volts. If no voltmeter, remove alternator and take it to parts store for testing.
If the alternator is bad and that is your only problem, the truck should jump start, but it will not go far unless the battery is charged. OK?
Oct 01, 2010 | 1996 Chevrolet S-10 Pickup
My 1994 Nissan Pickup was showing the battery light on and then I was drivving to work with the lights on and it started chugging and then died and would not start. Battery dead
The alternator is not charging,need to replace it,and charge the battery up with a slow charge,,,2 amp,over night a then some,slow charging gets the charge all the way up,and creates a deep charge that will stay,and prolong the battery life.
Apr 23, 2010 | 1994 Nissan Pickup
I just put in a new battery and alternator and my
First step is to check the voltage of the charging system. Should be around 12 volts when engine not running , 14 volts when engine is running.
If these test out OK then your warning light is the problem. Could also be a poor connection or broken wire at the alternator. Alternator must be grounded to work , but if it wasn't , the light would probably not come on.
Apr 08, 2010 | 1984 Nissan Pickup
1995 nissan pickup new alternator and battery
it is problem with main +ve supply for alternator from battery, fix new wire to alt to batt only for +ve supply and then try ,it will start charging,if it wont charge then problem with instrument cluster, only two could be cause.
Jan 24, 2010 | 1992 Nissan Pickup
95 nissan pickup wont start
if u cant find any info about the diode try a used alternator should b cheap fix
Mar 03, 2009 | 1997 Nissan Pickup
Battery not recharging
you may have gotten a bad battery,,,it happens we bought one awhile back brand new and it was no good have it tested
Feb 19, 2009 | 2004 Nissan Maxima
1996 Pickup Short Bed Xe Egr Valve Vacuum Switch Logo
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
