Question about Sharp Office Equipment & Supplies
I need sharp color copier AR C172M repair manual please
Bad copies with white line on paper
    New Friend:
    Problem Solver:
  • 6 Answers
Go to your google page and type in sharp color copier ARC172M repair manual and it will bring it up
Posted on Jan 15, 2013
  • 120 Answers
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
Benimur
  • 6966 Answers
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 17, 2008
SOURCE: Get an user manual for a sharp copier model #AR-M450N
sharp.com should have the manual to down load
Posted on Dec 16, 2008
SOURCE: I Need FREE Service manual for my Sharp AR-5320 B & W Copier
if you want the manuel send me youre email to gordon.myers@hotmail.com
Posted on Sep 14, 2009
SOURCE: I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Posted on Jan 09, 2010
Bad copies with white lines on paper sharp color copier AR C172M. opc drum or fuser?
could be either or LSU glass, or charge corona. inspect drum and fuser and look for similar patterns. do a skyshot (open the platen cover to make a black copy) and stop the copy process while the image is being formed (hit copy with the cover up, wait just a second, and open the side door while it still running the copy). This will jam it but you can see the toner on the drum and look for patterns.
Jan 15, 2013 | Sharp Office Equipment & Supplies
How to fix the sharp ar-c172m it keep saying initializing printer controlller and won't work
When the machine is still in initialization state would mean of of the parameters is abnormal , paper jam, ink empty, faulty sensor, if not a pcb fault.
Dec 25, 2012 | Office Equipment & Supplies
Sharp AR-M237
please clean the sensor and feed the paper
Mar 17, 2010 | Kyocera CopyStar CS-3060 Black and White...
We have the AR-M257 Copier. When I want to copy
Hello sir; Did you assign a tray for 11x17 and program it, if not, just follow your manual to program it.
Oct 20, 2009 | Sharp AR-M257 Black and White Copier
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
It dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
