Hotpoint Aquarius WF225 doesn't pump water out at end of cycle
The machine went thru a full cycle and finished its cycle still full of water, I can hear the pump but the water stagnates in the drum. Is there a filter blockage somewhere? Thanks
jsrock516
  • 5911 Answers
SOURCE: hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Posted on Jul 22, 2007
  • 3 Answers
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Posted on Dec 01, 2008
SOURCE: My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Posted on Dec 06, 2008
SOURCE: Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Posted on Jan 22, 2009
barkencoa
  • 3463 Answers
SOURCE: aquarius hotpoint wf541 wont pump the water out at
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Posted on Dec 28, 2009
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Are there any filters that need cleaning and are there any drainage points to move stagnate water ?
washing water is held in the pipe to the wash tub and in the pump under the machine
try using a straight wash (no clothes) with a high concentration of bleach in the machine or other available steriliser
repeat the rinse cycle after the wash has finished to ensure that any bleach is flushed from the drain pipe.
May 06, 2015 | Washing Machines
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD440 Washer/Dryer. After a cycle clothes still smell as if there is stagnant water underlying somewhere yet machine has been looked at - nothing wrong. Still working in excellent order...
You can buy a liquid product (I got ours in Lidl) that flushes out and cleans the machine. If one application doesn't work try it again. It's just like cleaning out the dishwasher. Worked for us and it was really smelling!
Aug 24, 2011 | Hotpoint Aquarius WD63 Front Load...
When a cycle is complete in my Hotpoint Aquarius washing machine, the conditioner drawer is full of water. Do I need an engineer?
When a cycle is complete in my Hotpoint Aquarius washing machine, the conditioner drawer is full of water This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 11, 2011 | Hotpoint Washing Machines
Hotpoint Aquarius wms38 1200spin Machine fills with water after wash cycle is finished and it is turned off
If the water is coming in after cycle has finished, then it is 1 of 2 possibilities.
1- A faulty inlet valve, replace it.
2-Water is syphoning back from the sink if it is connected to the sink waste outlet pipe, raise washer outlet hose higher up to solve problem
Nov 30, 2010 | Hotpoint Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Im getting f -05error towards the end of all programmes and cant get it to spin or pump out on a hotpoint aquarius wmf50
F05 means that the pressure/\water level switch is jammed on full.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove other end of hose onto pump, and check for blockage or obstruction here.
Please rate my solution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
