Question about Montgomery Ward Refrigerators
Hmg 2241-4 not cold and draining water
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I need a manual for the Bosch hmg 2210
don't know what a bosch hmg 2210 is. I don't own one. What is your problem with it?
why not just check online. might be easier than expecting us to find it for you.
Aug 19, 2014 | Microwave Ovens
Water insider refrigerator
I have water inside the fridge, icing on the bottom of freezer, objects on
bottom are freezing, but not items on top. It is a signature 2000, model # HMG, 21514 FROSTLESS REFER
Apr 12, 2013 | Refrigerators
Admiral- Model HMG 19153 Freezer is cold, but doesn't freeze What's the problem?
Is it set at max? Try switching to fast freeze. it bypasses the thermostat and may help find if it is faulty
Mar 27, 2012 | Refrigerators
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Oct 04, 2010 | Montgomery Ward Refrigerators
The center divider in our hmg-2170-4 is very hot. the fridge is cool and the freezer is cold, but the center is hot enough to burn you if you are not careful.
Your condenser fan motor (down by compressor) is not running. Either bad motor or something has blocked it. Also possible that condenser coils are filthy.
Nov 27, 2008 | Refrigerators
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Montgomery Ward Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Montgomery Ward Refrigerator Expert? Answer questions, earn points and help others
