Question about Frigidaire GLEB27S7A Electric Single Oven
Cant get the oven door back on
I have a whirlpool RF386PXEO the door slipped off and I am unable to get the hinges back in the slot
How do I get this door back on.
Thanks
  • glenjamin9 Feb 04, 2009
    worked perfect, it took me 30 seconds to put the door back on ....
    thanks for the help .....................
    President:
  • 1,214 Answers
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Posted on Jan 24, 2009
  • Mark Egan Feb 04, 2009
    Cool! Even a pig finds an acorn every once in a while.
    Let me know if I can help on anything else!
How do u get door back on whirlpool stove
physically open the hinge and then isrest the hinge bracket into those slots
May 27, 2015 | Ovens
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Need to reattach the oven door
most doors lift off. there should be some stops on the hinge .set them before remmoving door . but you have already got the door off so you will have to reset the hinge lever till the stop will hold then insert the hinge into slot and fold the door down . release the stops and door work work properly . mm .
Jul 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door won't go back in place
open each hinge about 1/3 of the way open or until it reaches the point that it will stay open, align the door slots with the hinges and lower the door down onto the hinges. Door should operate properly now.
Feb 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door came off
Just found this posted by tech17 (THANK YOU SO MUCH!) and it worked!
POSTED BY TECH17:
i posted the solution under premium problems i don't know how that works but what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
May 11, 2008 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RF396LXE2 Oven
Frigidaire GLEB27S7A Electric Single Oven Logo
277 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
