Question about Uniden Cordless Phone
Phone is off and lost phone
I have lost my phone and cannot hear it dial to try and locate it because it is turned off. how can i find my phone???
  • 98 Answers
If it is a house phone like in the picture look fore a pager butten or a speker button under the base
Posted on Jan 24, 2009
Samsung cell phone, I can not hear others
To locate your problem follow these steps:
1) Call your friend with your samsung. Try to activate speakerphone.
2) If you can now hear your friend on call, then your samsung EARPHONE needs replacing.
3) If you still cannot hear your friend, please adjust call volume (when making call) to see if device volume was turned down
Mar 30, 2014 | Cell Phones
I have plantronics cs 70 and this is connected to my cisco ip phone .the problem is i can't hear the other person on my phone but other persons can hear me ok.
You need to check all the locations of the dials and #'s, sometimes it is just a simple matter of turning a dial. Here is a link to the CS70 User's Guide that may help you.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
You cant here the dialing ton when calling someone
Hi, when you try to call and you don't hear a dial tone,is because the ear piece that makes you hear some one calls you is damaged and will need to be replaced.
Usually gets damaged by itself and to replace the earpiece, you will need to disassemble the phone to be able to replace the hear piece.
The earpiece is located atthe top head of all phones. And is easily to locate.
When you replace the earpiece you cannowhear the dial tone on your phone.
Thanks for using fixya.,.
Jan 11, 2011 | Cell Phones
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot dial but have dial tone, and they hear me, but I can't hea
I GAVE UP WITH NOT HAVING A PHONE AT HOME THAT WOULD WORK. YUP, I DID IT. I BOUGHT A NEW ONE. NOT ALL THE PROBLEMS ARE FIXED. BUT MOST ARE. AT LEAST I CAN HEAR THE CALLER AND THEY CAN HEAR ME.
Jun 29, 2009 | Panasonic KX-TG5632 Phone
Not able to dial out
the issue will be in the handset. please contact a panasonic service center. Please let me know your location so that i can try to provide you the address or contact no.
May 03, 2009 | Panasonic 5.8 GHz Additional Handset for...
Are one touch dialing board not working
When sending, try using a analog phone, and dial the number you are calling. Make sure it is the correct number. You might hear someone pick up the phone, or you will get a recording messege. This will tell you if the phone is the correct number you are trying to dial. When you are finished, plug in the phone line back into the correct jack on the fax machine.
Once you hear the dial tone, your phone is working.
If you can send a fax, and the machine does not send it, then the machines fax board might not be working.
There are other questions I like to ask about the phone line. Are you using a adaptor to convert the analog signal to digital? If this is the case then the adaptor may be causing some problems with your faxes.
Good luck.
Feb 27, 2009 | Xerox WorkCentre Pro 765 Laser Printer
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Ic502 nextel cell phone
dial * 720 then hit the talk button. you will hear beeps confirming call forwarding is off. to call forward you dial *72 talk.
Oct 22, 2008 | Motorola Mobility ic502 Cellular Phone
Mute is turned on cannot hear phone ring. How to turn mute off Mute is turned on . Have no dial tone can't call any one and can't answer the Phone How do you turn mute off?
I can't talk or hear outta my phone. I can dial people but i cant hear them and they cant hear. My phone model Cordless 5.8GHz Edge Dual Handset Phone System with Caller ID:
Jun 08, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
