How to add a DVD into TV - Televison & Video
  • Charles Mercer Jan 15, 2013
    Already have HDMI cable from cable provider, how do I now connect DVD to TV ? Do I run a cable from DVD to the back of TV into VIDEO? COLOR STREAM HD inputs ? Do I have to change input from HDMI to some other input??
    New Friend:
    Problem Solver:
  • 6 Answers
You need to buy a HDMI cable and run it between the TV and DVD player
Posted on Jan 15, 2013
  • janvoyager
    janvoyager Jan 15, 2013
    if it has two HDMI cable ports use that if not u have to run audio/vidio coaxel cable. On my TV the DVD player is listed under component when i bring up the menu. that is the port that was available for me to use.
Tv dvd combination is not taking a dvd
It does not require a special cable for the DVD it is attached to the TV internally. If the regular signal input cable is OK then the problem is within the set itself, which I might add is quite common
Gillight
Aug 27, 2012 | Venturer Klv39103 10 Under-Cabinet Lcd TV...
Tv/dvd combo no signal
if the unit plays DVD's fine but TV alone does not work--issue is with the TV----what is hooked up and how for signal and what do you see ?
To add information or ask more press the "make a comment" button on this page.
Mar 26, 2012 | Polaroid Televison & Video
Vcr tape doesn't show on screen when playing
If the picture from the DVD shows on the screen, but the pictire from the VCR does not, it is most likely because you are using sockets on the back of the player that are exclusively for the output from the DVD.
Please review your connections in relation to the diagram below. If the cables from the player to the TV are only in the red box, you will not get any picture from the VCR. You will need to move the connections to the sockets in the green box or add a separate connection for the VCR using the sockets in the green box. Whether or not this is possible depends on what input sockets are available on your TV.
You will notice the heading above the red box says "DVD". This means the connections in this section can only be used for DVD. The heading above the green box says "DVD/VCR" meaning the connections here can be used for both.
There are a fews ways to set this up. To get the best picture quality from DVD, you should continue using any connections you may have in the red box and add another cable from the green box to the TV for the VCR. You will also need to select different INPUTS on the TV depending on whether you want to watch DVD or VCR if you are using 2 cables.
I suspect this will be the cause of your problem. If you need any further explanation or assistance, please reply to me by clicking on "Add a Comment" below your question. If you would like me to draw a connection diagram between the DVD/VCR and your TV, please let me know the brand and model number of your TV.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Emerson EWR20V4 DVD Recorder/VCR
How to hook up the componet cables to the tv so i can watch dvds using the dvd player
Just hook up the audio best available DVD (or any) to this unit and the video directly to the TV. Running video through an HTS may add simplicity but it also adds two connections that could be points of failure or produce distortion, voice sync problems, etc.
Jun 01, 2010 | LG LHT854 Theater System
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Insignia tv ..can't get sony dvd to work
You most likely need to set the TV to the input source where the DVD player is connected (e.g. AV1, HDMI2, etc.) Without knowing the model number of your TV, I can't be more specific. Details on changing which input source you're viewing should be in your TV owner's manual.
Sep 19, 2009 | Sony DVP-NS55P DVD Player
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
How can i add a monitor to fact overhead tv/dvd
you would have to get a schematic of the wiring either from the car manufacturer or website then it would be basic splicing and connecting. down side is tearing apart your ride for the new monitor. if you need more installation help sure someone can answer ya for a premium
Jan 20, 2009 | Kenwood KSC-WA100 Car Subwoofer
I want to add a DVD recorder into my TV set up
If I'm right On the DVD recorder there should be an aerial input and an output. Connect external aerial to the output then run a second from the output to the TV. Then use the HDMI to connect the DVD. This will then give you the option of recording one channel on the DVD whilst watching another thru the receiver thats built into the TV. You will then get the best poss picture when viewing DVD
Nov 25, 2008 | Televison & Video
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
