Canon mf4340d scan - Office Equipment & Supplies
How can I install "scan" option in display of Canon irc3170 printer?
http://www.usa.canon.com/cpr/pdf/Brochures/copier_c3170_spec_sheet_rev.pdf
Canon Contact Us
According to the Cannon web site, the 3170 series printers do have the scan feature. I suggest you contact Cannon directly for information about the scan feature.
May 01, 2014 | Canon imageRUNNER C3170U Color Copier
Mf4340d. How do I reset?
Is the toner you have third party or OEM, check for any metal contacts and clean with alcohol, also clean where they meet in side the machine do not touch the contacts with your hand oil from hand can cause issues. Also go online to MF web site download op manual normally free.
Jan 08, 2013 | Canon Office Equipment & Supplies
I can print from my canon mp160 but i can't scan. how can i do for scan.
Scanning can be performed with the MP Navigator software. Please open the MP Navigator from your Desktop or the Canon Utilities listing of the Start Menu (Windows) or Applications folder (Mac).
Hope this helps you.
Sep 18, 2012 | Canon PIXMA MP160 All-In-One InkJet...
How do i scan a document to my computer with the canon mx328
Install the Canon scanning software, and use "MP Navigator" software to scan your documents.
Canon PIXMA MX328 software download @ http://support-my.canon-asia.com/P/search?model=PIXMA+MX328&filter=0&menu=download
Hope it helps.
Aug 10, 2011 | Canon PIXMA MX310 All-In-One Printer
I need canon irc 3100 scaner driver i connected printer but i cant scan
u can open canon india website and select your model no. and download the network scanning driver after download u can install your system and use photoshop for scanning, choose online scanning option in your zerox machine and scan through photoshop (click File-Import to canon network gear ver. 2.7. u can use feeder also while scanning
Dec 02, 2010 | Canon iRC3100 Printer
How do I get the Canon image runner 1023if to scan documents? I have followed the instructions provided by Canon (what little there was) loaded the drivers, (as per Canon) and still cannot get past the...
Try using different software for scanning. e.g. Photoshop Select the right scanner, for Canon you usually see WIA. Then import image and select Canon. New window will pop-out and you can start scanning. Be sure to press the SCAN button of the machine before scanning.
Jan 26, 2010 | Canon imageRUNNER 1023iF Black and White...
How do I work my scanner?
You can scan from My computer> Canon pixma double click and scan. Also if you use professional tools such as Photoshop you can scan fron File>Import>Via canon pixma....
Canon also have its tool for scanning. Install original CD and it will have.
Aug 03, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon MP830 not scanning
It won't scan unless you have a program like picasso running on your computer to accept the scan. On the Canon you choose where you want the scanned image to go and if you choose the computer you need a program running to store or adjust the scanned image.
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
Canon MP600 won't scan
i would say maybe first step os to unistall all canon mp600r software includin scanning programs and reinstall them and see if it then works. this might cure your fault but make sure you do it from the setupdisc not the canon website.
Hope this helps
Oct 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
k24674
