Question about Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic DMC-FZ50 flash is not working.
There is flash sign crossed out on the screen and I can not turn it on. It started about few months ago but when I played with ( switched off - on or opened and closed the flash few times, or played with the program button) sooner or later I was able to get the flash working but it is not possible any more. Any advise? Thank you Best Regards Alex.
SOURCE: panasonic lumix dmc fz50
FIRST YOU HAVE TO CHECK THAT YOUR PC PICKS UP THE CAMERA AS A EXTERNAL DRIVE IN MY COMPUTER. IF NOT THEN THERE MAY BE A PROBLEM WITH THE CABLE OR THE JACK ON THE CAMERA. THIS DOES GET DAMAGED IF YOU DO NOT PULL THE CABLE OUT STRAIGHT. DO NOT WIGGLE THE CABLE.
Posted on May 27, 2008
  • 3 Answers
SOURCE: external flash for dmc-fz50
I can't totally answer your question, but please look to the Olympus fl-36 OR metz 48 af-1--both are 100% compatible. The FL-36 is way less money than the pany equivalent--trust me its the same exact flash as the Pan FL360.. For a little more money, the metz is slightly more powerful, but you loose the "auto thrystor" feature. The oly is a lot smaller as well.
I have the FZ-50 and have used both flashes.
Posted on Jun 15, 2008
Vladimir Z
  • 86 Answers
SOURCE: Panasonic DMC FZ50 digital camera
when you are replaying your pictures you use the front turning switch, not the manual focus ring.
Hope I helped, please rate my answer if you like it.
Vladimir
Posted on Oct 15, 2009
SOURCE: Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Posted on Oct 08, 2010
  • 11967 Answers
SOURCE: I have dmc-tz5. It workes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 02, 2010
A battery for panasonic DCM FZ50
possibly from a battery supplier but not us here on FIXYA .
Aug 20, 2016 | Panasonic Cameras
My flash isn't working anymore!! (fz50)
Find the setting for "conversion lens" in the menu, or tools menu.
Turn it off.
Turning the "conversion lens" on blocks all flash function.
The conversion lens is a extra lens that you can purchase to screw onto the front of the main camera lens for extra zoom or wide shots but it blocks the flash, so your only meant to turn it on when you have one fitted.
Sep 25, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
I cannot see through my viewfinder to take a picture, but can take pictures on the LCD monitor on my DMC-FZ50 digital camera. Joan
There is most likely a setting in the camera's menus so that you can switch between live view and the eyepiece. Search around, or check your manual.
Jul 07, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
I have lost my instruction manual for my Panasonic DMC FZ50 and wish to replace it. I live in Wellington area NZ.
Hi. I found the website to download the user manual for your Panasonic DMC FZ50 . Here is the link.
http://sils.unc.edu/itrc/its/lab_resources/manuals/LumixDMCFZ50-manual.pdf
Just double click on the link or copy and past in the address box and save it on your computer.
GOOD LUCK!!!!!!!!!!!!!
Jun 16, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Vladimir
Sep 28, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic DMC-FZ50 Digital Camera
No, there is nothing like that. If you need advice, ask me, I will try to help you with the settings. vladio2000@yahoo.com
Aug 31, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
External flash for dmc-fz50
Okay, first off, Panasonic makes several external flash units that work with this camera. The FL360 seems to be the best buy, though at around $300 it is not exactly cheap. It has TTL and I am very happy with mine. I bought a cheap Sunpak to use with my older FZ30 but I think the voltage was too high, as it stopped working with the hotshoe. I would not recommend using any flash that is not rated to work with a digital camera. The problem is, almost all that are currently made are designed to work with specific camera models. So, the Panasonic flashes seem to be the way to go. There is also a FL500, which has a higher guide number, but it is close to $500.
Now, you don't necessarily need FL360s or even digital flashes to work with a slave unit. I have one I picked up at a camera store to use with my Sunpak as a second off camera flash. As long as you have a flash to trigger them (i.e. the built in flash, or something like the FL360) any flash with a slave trigger will work. One other possible solution is a device also made by Wein that allows you to use an older flash with a digital camera. It reduces the trigger voltage and prevents damage to the camera. I have one on order, not to use for that purpose, but because it also allows one to use a plug in flash with a camera that lacks the appropriate place to plug the flash in. I hope that helps.
Mar 17, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic Lumix - LCD & viewfinder WHITE
my camera just did that to me yesterday..i had t for like a week.. did u have a warranty on it or something like that?? i have to take mine back to the place were i got it and go talk to them about it.. my screen is like shot or something..
Feb 21, 2008 | Cameras
Trouble with my panasonic fz50
CAN YOU SEND EXAMPLE PICTURES, OR DESCRIBE THE FAULT IN DETAIL.
Oct 31, 2007 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic Lumix  DMC-FZ50K Digital Camera Logo
54 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
