Question about Lexmark X1270 All-In-One InkJet Printer
The paper will not load correctly
I was using the printer and one page seemed to go into the machine crocked and then the rest all did the same.I have note since I bought it that it often grapped extra sheets of paper.I just load two new cartiages,so can it be fixed or should i look for a printer that uses the same cartiages?
    Genius:
  • 2,035 Answers
This not the problem with cart ,this is the problem rollers ,please these steps
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 24, 2009
My magicolor 2200 keeps asking me to put paper in the mpt (multi purpose tray) when I'm printing form the bottom tray. The resulting print comes out slightly smeared and starts part way down the page. ...
ok seems like 1 of 2 things,,, firstly check your print settings and ensure your selecting the correct try to print from..
turn off machine
might be a stuck sensor, turn off machine look at where u load the paper, close to where the printer pulls it up, there is a small leaf swith there that tell the printer if it has or dont have paper, play ith the switch a bit.. Then turn back on and try again.
Apr 02, 2011 | Minolta magicolor 2200 DeskLaser Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Leading edge detection error When loading paper into printer this is displayed on the lcd scren
This is caused when the size paper loaded into the machine does not match the size the machine expected. Check the paper size settings to ensure you are using the correct paper setting. This also can be caused if paper loaded does not align correctly.
Jul 09, 2009 | Canon imagePROGRAF iPF8000 Printer
HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | HP Photosmart C6280 Printer
Keeps popping up "paper source setting not set properly"
I'm guessing (wildly) that the printer is an R2400 (although there's no guarantee of that it seems :) )...
Anyway, the problem is most likely to be in the printer driver settings used on your computer.
You need to go to:
- Start
- Printers & Faxes
- Locate your printer
- Right click on the printer and choose "printer preferences"
From here you need to ensure that all your settings for paper size, etc... are correct.
You also need to ensure that whatever you're actually printing has the correct page setup using the same paper size.
Hopefully that will correct your problem.
Feb 14, 2009 | Epson Stylus Photo R2400 InkJet Printer
Canon i950 ... paper will not load into printer.
Dear tigerdawg,
As my longtime experience, it seems that any other material such as broken paper,etc present inside paper path of your printer. Please check and remove the material. If you cannot do this by yourself you may ask someone or take the printer to the nearest service center. I hope this help you then rate this as fixya.
Regards,
Nov 30, 2008 | Canon i950 InkJet Photo Printer
Blac Spots on right side of page
This generally happens when,
The paper is mismatched to the paper setting for the printer.
For example, if you are using high-quality photo paper, set the printer's output for that paper; do not use the plain paper setting.
Post your response about how things turned up and i can help you up from there.....
Oct 01, 2008 | HP Deskjet 6940 InkJet Printer
:Load Papers"
Hi there this should be a simple one there are three suggestions the first one if you goto word or which ever program you are using goto file then select page setup once in there check the paper size is correct to the paper that is in the machine and check that paper source is from tray (Cassette) I trust this is the only printer on your system if not you must select this printer before you start the above.
The second on is in the properties of the printer goto start printers and faxes the right hand click on the printer and select printing preferences. Once in there check that you are set for the cassette for paper feed and the print size is set to same as original.
The third one is on the machine itself go into the menu and select paper handling and set the cassette to be used first and make sure it is set to the correct size paper as well.
The most common one would be the first one as not many people change the settings within the driver or the machine.
Hope this is some help to you
Thanks J
Dec 27, 2007 | Ricoh Aficio CL2000N Laser Printer
Lexmark X1270 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
