Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Compaq presario 2100 laptop, starts, then restarts
Starts up , then goes to black screen listing :
start in safe mode etc, doesn't matter what you choose, it flashes a blue screen too quickly to read what it says, then restarts again
  • chrislk1986 May 11, 2010
    Do you have the OS CD in the Drive when you start up?
  • Compaq Master
  • 27,725 Answers
This could be a memory dump you might not have enough ram installed on your computer causing to much stress on the cpu at startup
(to many programs running at the one time) scroll to the bottom of your screen toolbar right click select task manager applications & processes you will see what is running if you see something you dont need running select end now you might need to install more RAM
click start right click on my computer select properties you will see all imformation about your computer including installed ram and available ram
make sure the ram modules are securely seated with no dust in the sockets
if you dontant to install more ram you could uninstall some unecessary programs
th ones accessing the computer at start up or
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if I have misunderstood the problem post a reply
hope this helps you
Posted on Sep 26, 2011
  • 4 Answers
I have compaq presario 2100 i was using for 7 months now the screen is black can give me any solution
Try booting in safe mode by pressing the f8 button after the bios post choose safe mode and if you see the display just go to device manager through right click on the my computer and manage and display driver right click and uninstall and restart the comp and should be fine\
Dec 05, 2010 | Compaq Presario 2100 Series: 1170B01-90...
Screen goes black after login
boot in safe mode or vga mode by holding f8 on startup. If you can see vga or safe mode the resoution is too high for the card or monitor. Once in via reduced mode uninstall your video driver and reboot. If it tries to add a driver make sure to set the resolution lower. If low resolution doesn't work then you may have a hardware problem.
Nov 07, 2009 | Compaq Presario 700 470024-192 Notebook
My Compaq Presario 2100 laptop won't boot up
Try removing the battery, then put it back. Plug the charger and charge it first, then start over.
Aug 13, 2009 | Computers & Internet
I have a Presario C500 Compaq laptop
when upower up press F8 key then enter in enable vga mode.
then set screeen resolution to 1024*768
and if u r not abled to login enable vga then enter in safe mode.
then go to start menu run then type in run "chkdsk /r"
thats it
then restart it then it fix error on hardddisk.
Jun 08, 2009 | HP Compaq Presario C500t Notebook
Laptop won't start up
It sounds like your laptop is using it's external VGA adapter for its main display. Try holding down the Function (FN) on your keyboard located on the bottom left hand side and pressing F4 at the same time.
Jun 04, 2009 | Compaq Presario Notebook
Black screen white writing...
Restart and keep pressing f8. Select safe mode and see if you can login to safe mode. If that is not possible then keep pressing F10 key to start recovery tools. Just follow instructions on the screen in recovery tool to recover your Notebook back to factory settings.
If there is any important data on the notebook, then use data backup tool in REcovery utility.
Please leave your feedback if issue was recolved
May 27, 2009 | Compaq Presario 900 /1500 Series EVO...
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
Compaq presario 2100 laptop, starts to run, then goes to black screen with start in safe mode etc, then a blue box appears, gone before you are able to read anything that it says, then laptop restarts...
Check the mounting screws on the cd burner,yes you have to remove the keyboard and speakers,and check the two visible mounting scews.....I rescently bought a used presario and discovered the yo-yo didn't mount the cd rom properly(no screws)...The screen you saw flashed is the BIOS,also check fitment of all plug in type accessories......
Jan 24, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Keeps restaring...
did you try last known good configuration?
Feb 22, 2007 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
378 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
