Question about Maytag 30 in. Admiral LGC1330 Gas Cooktop
Pilot Light Won't Stay Lit
Whenver I have to use my stove top, I have to light it manually because the pilot light won't stay lit. It worked for awhile just fine, but after cooking for several hours it stopped working. I'm not sure what I can check for to see what the main problem is. Any help would be greatly appreciated!
3 Suggested Answers
  • 222 Answers
SOURCE: maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Posted on Jul 04, 2009
  • 1515 Answers
SOURCE: The electric strike on my cook top wont stop
The problem is in the pilot ignitor Located under top, unplug the unit before replacing it. Write down all of the information ,mode, serial, and product number and name of stove. If you can get a part number, this would be very helpful. Take this to a local appliance parts house and they can help you.
Sincerely, shastalaker7
Posted on Oct 30, 2009
SOURCE: I have a Maytag performa Kitchen stove and all 4
Its electric
Posted on Aug 10, 2011
0 characters
1 Points
Will not stay lit
There is a piece that senses the pilot that can go bad. Usually a piece of copper with a bulb right in front of the pilot on one side that screws into the gas valve try replacing that
Sep 06, 2014 | Wedgwood Wedgewood RV Range 21 In. With...
I can not start the oven. The gas is on and the cooktop is fine.
The oven either has a pilot light to be lit before the oven will work or you need to light the burner each time you use it. Check your owner's manual or find the owner's manual on line and read it!
Dec 26, 2012 | Cooktops
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Mar 13, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help:
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Rv cooktop range 22 series
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Maytag 30 in. Admiral LGC1330 Gas Cooktop Logo
193 people viewed this question
Top Maytag Cooktops Experts
Barrett Palumbo
Barrett Palumbo
Level 1 Expert
Gere knutson
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
