Question about St. Moritz Momentum by St Moritz Pedometer Watches (Back)
Manual for SW 650
Set up
How can i change the time
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
  1. To enter time setting mode, press and hold NW until the Seconds start to flash. (You can exit time setting mode at any point by pressing NW twice)
  2. Release NW and press SE to reset the Seconds to 00.
  3. Press SW and the Hours will start to flash.
  4. Set the hour by pressing NE (down) or SE (up) Press the lower button to move up and the upper button to move down.
  5. When the hour is correct, press SW and the Minutes will flash.
  6. Set the minutes by pressing NE (down) or SE (up)
  7. When the minurtes are correct, press SW and the 12/24hr setting will flash.
  8. Switch between 12hr mode and 24 hour mode by pressing SE.
  9. Press SW and the Year will flash.
  10. Set the year by pressing NE (down) or SE (up)
  11. When the year is correct, press SW and the Month will flash.
  12. Set the month by pressing NE (down) or SE (up)
  13. When the month is correct, press SW and the Day will flash.
  14. Set the day by pressing NE (down) or SE )
  15. When the day is correct, press SW and the seconds will flash again.
  16. Exit time setting mode by pressing NW twice.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
Apr 02, 2014 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
How to get less spin than 650 ?
We could not answer this without knowing the make and model of your washer of course. Also it might not be possible to go lower than 650 if that is the lowest indicated/selectable ;-0(
Methinks you could do with a manual for your washer- for now and probably later!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 31, 2011 | Washing Machines
Looking for float setting for 1981 yamaha 650 maxim
You would have to buy a service manual for that bike it will tell you all the carb settings in it.
Jul 29, 2010 | 1981 Yamaha XJ 650
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
I have that same problem but i own nikon D60 what settings do
M (Manual).
You won't get autofocus, nor will you get any metering. It's completely manual.
Aug 28, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Resetting the demo mode
turn off with OFF sw.
Press WARMER / COLDER sw for 5 seconds
While maintaining warmer / colder turn ON with ON sw.
SHOULD NOW TURN ON
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
When is turn off the swıcht rpm indicator is not comıng zero..
Battery condition? Make sure battery connections are clean and tight this is a very common problem.
Mar 12, 2009 | 2004 BMW F 650 GS Dakar
My treo 650 turen and off atomaticly weth out itach it in must of
I notice the same problem today. It is a config., a SW, or a HW problem. It is more likely the former two than the latter. What I did to test it is to do a warm (?) reset by holding the 5-way up from reset until finish booting up. In my case, the screen did indeed stay off in this mode. So, it is either a config. or a SW that is causing the problem. Since I did not install any new SW, I figure that it is the config. No, I did not find what SW config. caused the problem. What I did to fix it was to restore "saved preferences" and "unsaved preferences" from back-up. I wish you success and a happy new year.
Jan 02, 2009 | Palm Treo 650 Handheld
Fax b120
net sw is network switch and is used in Oz and N.Z. to reconise Telstra Duet System, should work anyway just ringa little different, if you press receive mode button,setting should cycle everytime you press it and will lock to any setting displayed if you press start. sounds like you want "fax only"
page 65 user manual speaks of it
http://apparat.conagri.se/pdm/50524Canon_FAX-B115-120-140_enbr.pdf
Oct 28, 2007 | Office Equipment & Supplies
St. Moritz Momentum by St Moritz Pedometer Watches (Back) Logo
70 people viewed this question
Top St. Moritz Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a St. Moritz Exercise and Fitnes Expert? Answer questions, earn points and help others
