Question about MSI KT4A Ultra (MS-6590-050) Motherboard
Tower turns on monitor shows no signal
I tryed to reset cmos and still got nothing every thing on the tower is running but we get nothing please help
  • 2,229 Answers
I am guessing what you mean is that the monitor won't turn on. Does it have a green light or a yellow light that turns on?
If it is plugged in, there should be a light. If not, the monitor is bad. If the light is on but there is no video, then your video card has gone bad.
Posted on Jan 24, 2009
Emachine t3120 has no image
The CMOS Battery on the motherboard may need replacing. Also double check the monitors ok (Simplest thing first)
May 05, 2013 | Computers & Internet
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Monitor keeps saying no signal.Tried a new cord from monitor to tower but that did not help.The light is on the monitor to show that it is on.Help please.
connect another working Monitor to the tower, if this solve the problem send in the monitor to the monitor's authorised repair center. If the problem is not solved, replace the Vedio card on the tower
Dec 28, 2009 | E-Machines eMachines Monitor E15T4
My screen is showing Self test feature check and will not stop! Help!
The first thing to check is--is your computer actually running?
It sounds like your computer is either off or it is not sending a video signal to the monitor.
If there was a signal going to the monitor, you would be seeing something other than self test.
There is also probably a menu button on the monitor. Find it and push it to reset the monitor.
Now check your computer--preferably with another monitor to see for sure what is going on.
Oct 22, 2009 | Dell Computers & Internet
Cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
May 19, 2009 | HP GX613AA Pavilion A6300F Desktop PC
No monitor signal
make sure pc is off ,make sure video card is seated properly if it is try resetting cmos there is 3-pin jumper ususlly by battery and usually says reset cmos by it I have seen many differences according to mobo this can also be accomplished by taking out the mobo battery (the little round silver battery) if you have jumper take off 2 pins its on know put on other 2 for 1min then put back turn on, if removing battery take out then turn on pc
May 16, 2009 | Computers & Internet
Black screen on monitor
Hi there
Remove the side panel from the desktop and clear the cmos >>> cce5f1a.jpgmove the plastic jumper to the other position, and turn the machine on, if nothing happens, you have cleared the cmos, put the jumper back in its original position and see it the PC boots. If there is no Jumper, take the battery out for an hour.
Remember to remove the power cord before you take the side panel off.
Post back with the results please
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Microsoft Windows XP Home Edition
change the memory card, then reset the cmos. if problem persists change the video card, its probably bad.
Jan 24, 2009 | Intel Motherboard
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
MSI KT4A Ultra (MS-6590-050) Motherboard Logo
121 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
