Question about Refrigerators
I need help replacing the compressor control thing on my whirlpool gold side by side refridgerator.
  • 198 Answers
If you mean the compressor, you are out of luck, time for a new frig
Posted on Jan 24, 2009
The compressor relay on my Whirlpool Gold side-by-side refridgerator just caught on fire. Reading feed back there apears to be aproblem with this. Is it repairable? Should I buy a new frigde?
just replace the rtc overload contactor,it unplugs from the compressor,then when the new one is installed on the compressor,check the current draw of the unit with an amprobe
Feb 20, 2010 | Refrigerators
Motherboard for whirlpool gold conquest gs55shaxnb00 I'm thinking of buying (actually free) a 2004 whirlpool gold conquest refridgerator that needs a new motherboard. Does anyone know about where to find a...
The control board , down by the compressor , pt # 10135090 , only costs about $100 . I would suggest getting the refrig , if you know that is the problem . You can get/order from any appliance parts house , or , order online .
Sep 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest Gold White Model# - GS6SHAXLQ03
The relay is the start device,but you need to determine if you need it,try to see if you have power to the compressor,is the compressor running,is the condenser fan motor running,is the coil under the unit clogged with dust,if the fan under the unit doesn't run it will overheat the compressor and it will go off. and if the coil is clogged the same thing goes.
 Usually if the relay is bad the compressor will make a hum and a click noise but will not actually run.about every 5 minutes..
Sep 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
