Question about HP PSC 2210 All-In-One InkJet Printer
Lexmark 5400 series printer
Display showing "clear the carrier jam{" what is solution for this
  • 3 more comments
  • Anonymous Jan 27, 2008
    When I turned on the pc, I noticed the printer was in the bottom of the screen, like as if it was going to print but it wasn't doing anything.. It did not print anything from Adobe Reader, & didn't understand why not. When I tried to print something else, it goes thru its printer menu, then when I go to print nothing happens.
    Thanks,
    CHARLES PERSON, SR.
  • Anonymous Feb 03, 2008
    i want to install lexmark 5400 series all in one printer but i have know hard drive i am connecting to a lop top computer
  • Anonymous Feb 17, 2008
    when i turn on the printer it shows the error message" clear the paper jam then press ok ". I have checked out, but there is no paper in printer and there is no paper jam.Plese help me to solve this problem.
    Thank You
    Gurpreet Randawa
  • Anonymous Mar 18, 2014
    clear carrier jam
  • Anonymous Mar 24, 2014
    It started displaying that printer error has occurred and displays 5400
  • 3 Answers
Just today, our Lexmark 5400 began having paper jam issues. We'd try to print, and the paper would initially feed into the back and then wouldn't go any further. Then it gave printer jam error messages. After peering and poking into various areas of the unit I wound up disconnecting the printer from power, phone line, and USB connection, I took it to a better lit room.
Peering carefully into the back paper feed area, I discovered a pencil!! After excising the pencil, the printer worked fine. One of my precious children must have accidentally dropped a pencil into the back, or a pencil was resting on top of the unit and rolled into the back paper feed area.
Lesson learned, don't put pens or pencils on top of the printer.
Posted on Jan 17, 2008
My color ink cartridge hasa run out. I replaced with a black cartridge. Error message appears - "right cartridge incorrect." Can I have 2 black cartridge's in at the same time? I don't want to buy another color. Nothing seems to work - I have to have the color ink cartridge in, or nothing prints - now I have run out of color - what am I doing wrong?
thanks -
Posted on Jul 09, 2008
Mine is doing the same as the one who had a pencil stuck in it. But I have unhooked everything and unable to see any type of object(s) in the printer. Is there any suggestions that you may have to this.
Bobbie
Posted on May 15, 2008
Won,t print letters
Posted on Mar 05, 2008
    Genius:
  • 2,985 Answers
Make sure there are no paper debirs in the paper feed track- this may only be a crumb that is causing it. Vacuum the track. switch the printer off and disconnect from the power supply whilst do ing this. Then reconnect and with a ticker piece of paper or thin card try a paper feed. You could also take at look at www.fixyourownprinter.com
Posted on Jul 10, 2007
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
What's a Carrier jam?
Carrier Jam means that the Carrier which carries the cartridges is not moving correctly in this case please follow the below Steps:
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
May 07, 2013 | Lexmark 3-Pack Axis 5400 Print Server .:...
My lexmark x5630 x56xx series displays carrier jam the carrier bangs to the left, i saw a thin strip of plastic in the printer looks like its broken off from something please help
just try to fix it .but i think it is broken so you need to replace the broken part i advise you to show it service center.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Whether a scanner can be used without catriadges in all-in-one?
The printer wont function properly if it is jammed whether you only want to use the scanner. Try following the instructions in this site:
http://tinyurl.com/m8lv52
Jul 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
It seems you have some piece of paper in the carrier.
Could be just a very small piece somewhere in it... remove the cover and take a very close look. Check all rolls if they are loose or if something is locking them.
Jul 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
My lexmark 5400 keeps saying "clear carriage jam". I cannot see anything jammed but i can't use it till whatever is cleared. please help!
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
If the error exists .. then printer is defective contact lexmark ..
Mar 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
HP PSC 2210 All-In-One InkJet Printer Logo
1,356 people viewed this question
Clive
Clive
