Question about Kenmore Refrigerators
Kenmore 106.568 need defrost information
How to do a manuel defrost
Refrigerator make and model - GE TFG27PFX[A] Refrigerator side is ok freezer does not freeze as it should. display indicated PF. on inspection i found the bottom cooling coil frosted , but nothing...
This model is an older unit, so when you stated frost how much? Is the fan running in the freezer? If you have a-lot of frost in the freezer you could have a defrost problem. Most common in the unit was the heater would fail to work over time. There is 3 different components that control this function, defrost timer, defrost heaters and defrost terminator. All three have a purpose and a job, they depend on each other to complete this cycle.
Here is a link on GE and Defrost System
I hope this helps you, If you need time to complete this or what for parts, you can defrost the unit, and it can take up to 3 - 5 days to re-occur, yes the unit will do this again unit repaired correctly.
Good Luck
Aug 19, 2011 | Refrigerators
I can not turn on the freezer, It just keeps on blinking. It is a stand up freezer with the controels on the top of the door. Lost my manuel. It is suppose to go to -3.
Its stuck in defrost mode, find the defrost timer at the rear of the unit down near the compressor, turn the small dial clockwise and it should fire up, if so, spray that dial with lub and rotate it a few times. hope you get it sorted. Russ
Jun 27, 2011 | Freezers
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
Jan 07, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
Need to know how to defrost on R200BW sharp microwave oven.
I know this is NOT the exact manuel...after 2 hours i had not much luck. But i did see most sharp key pads are a like. I think this WILL work / help see page 16...the whole page. http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R820B.pdf Sharp is stingy...can buy the manuel here. http://www.sharp-cart.com/ecom/accessories.htm?action=getSearchItems&ss_id=1533&view=catalog/ss_items Every one elese is looking for a free fix also...lol Good luck
Nov 06, 2010 | Sharp Vacuums
Refrigerator keeps defrosting freeze?
you have the same problem with viciab09...your temperature controller is already out of order...try contacting a repairman and install a new one.
Mar 11, 2010 | Refrigerators
Defrost, heater fan and air won't work on my 96
just a guess but being that the rear defrost is not woking id bet ist a fuse check owners manuel or go to a local autozone or the like store as thy should check this for free hope this is helpfull.
please post response good luck
Jan 07, 2010 | 1996 Saturn SL
A/C Vents
cable lock mechanism on air diverter plate is broken.probably at control panel rear arm point. haynes manuel at auto parts store shows repair procedures.
May 09, 2009 | 2001 Chevrolet Astro
Intermittent failure
Sounds like you have a defrost safety thermostat not opening when the temp comes up on defrost. These can be solid state or the standard kind have a bi-metal switch. and if its solid state there is a check out procedure for it. Id need to review my manuel not many GE's around here.
Mar 11, 2009 | GE PTS22LCS Top Freezer Refrigerator
Manuel
Go to managemyhome.com and register. This is a FREE service. Once registered, go to the "Home Manager" drop down menu and click on the "Owner's Manuals" link. Follow the instructions on the next page by providing your make and model number. Your manuals are listed in a downloadable .pdf format. All you need is Adobe Reader installed on your computer to view. I hope this helps you.
Jan 15, 2009 | Whirlpool MH1150XMQ Microwave Oven
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
