Question about Electrolux Aerus Lux Guardian 9000 Canister Vacuum Cleaner
Where is motor reset button for electrolux lux 9000 vacumn
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
Can't open vacuum bag compartment
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Nov 10, 2014 | Electrolux Aerus Lux Guardian 9000...
Power Surge Electrolux double oven EI30EW45JS, now producing F11 code, installed new board, how to reset to see if problem is fixed?
Good Morning Jennifer Lynch, thanks for your post!
I see you have replaced the control board on your Electrolux wall oven and it is displaying an "F11" error code. "F11" stands for a shorted keypad, since you have replaced the board I would recommend resetting your wall oven. You can reset your wall oven by flipping the household circuit breaker off for ten minutes. If you need further assistance please feel free to reconnect. I hope this is helpful. -Matt
Oct 13, 2014 | Electrolux EI30EW45JS | 30" Double Wall...
On my Electrolux wave touch range, the burner buttons remain lighted, won't go onto sleep mode and when touched will not cause a burner to begin heating. It's as thought they are all stuck in the ligh
Hello friend, thank you for your post!
I understand that your Electrolux range burner buttons are remaining on. I have identified a few possibilities as faulty burner buttons, bad switches, or a disruption inside the control panel. Let's perform a reset on your range which can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue I would suggest consulting with a professional for proper repair. Hopefully this helps. -Matt
Oct 11, 2014 | Electrolux EW30MO55HS | 30" Built-In Drop...
Have a lux legacy c 153c made by aerus comes on and runs fine for maybe 90 sec then shuts off and in about 90 sec will come back on .has great suc and runs great while runing
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor.
I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off.
Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops.
I hope you post what you find out!
Jul 28, 2014 | Electrolux Band Aerus Lux Legacy Canister...
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Jul 22, 2014 | Electrolux Band Aerus Lux Legacy Canister...
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
Sep 25, 2013 | Electrolux Band Aerus Lux Legacy Canister...
Reset buttton location
The reset button for the power nozzle in on the top of the housing just to the right of the wand to tool connection. As for the tank; this is more a guess than an answer: There is a small hole at the bottom of the bag compartment. I wondered if that was a reset button, but the manufacturer recommends disconnecting the machine until it cools down and resets itself.
I know it is not much help. Electrolux Aerus does not want customers to repair their own equipment, and they will refuse to give out information.
Jan 15, 2013 | Electrolux Band Aerus Lux Legacy Canister...
Electrolux Aerus Lux Guardian 9000 Canister Vacuum Cleaner Logo
80 people viewed this question
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
