Question about Ovens
My frigidaire oven knob quit working. The knob turns but it does not adjust the temp.
I think the part number is 5422317
  • Cyndie Howell Jan 15, 2013
    I forgot to say this stove is a 1950 model rm-35
    Problem Solver:
  • 6 Answers
The knob is probably stripped. if the stove is from 1950 you may want to consider replacing it. If it is not to expensive to replace the knob you can try that just email the company and see if they can send you a replacement knob
Posted on Jan 15, 2013
SOURCE: Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Posted on Jun 28, 2008
barkencoa
  • 3463 Answers
SOURCE: frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Posted on Dec 14, 2008
  • 126 Answers
SOURCE: oven does not turn off completely
You should pull the knob off and check that there is a metal liner in the knob itself. These sometimes fall out and the plastic knob does not turn the control properly. Get a new knob at your local appliance store.
Posted on Jan 20, 2009
  • 160 Answers
SOURCE: removed dial knobs, put back on oven doesn't work
possibilities are that the spindle retaining clip is missing giving the impression that the oven thermostat is being turned when infact it i s slipping, or the oven is in auto mode if timer model.
Posted on Feb 22, 2009
SOURCE: F1 on frigidaire stove
Most F1 codes for frigidaire state bad EOC (clock) but the temp sensor is the least expensive place too start.
Posted on Mar 18, 2009
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
Oven runs hot not responding to temp knob.
refer to your use and care manual and there is a section on adjusting/calibrating the oven temps. tip do not use a small thermometer from the grocery to adjust your oven. buy a decent digital style...... then turn you oven on and let it cycle 3 times, that is elements come on then go off = 1 cycles. then watch the temp scale. record the temp when element turns off,,, then them temp when it turns on. add the 2 temps together then divide by 2 and that gives you the temp the oven is maintaining. then adjust accordingly. DO NOT ADJUST PER THE HIGH OR LOW TEMPS. use the middle temp as described.
Jan 31, 2012 | Ovens
The oven temp is 100 degrees hotter than the set temp.
On most oven temperture controls, if you pull the knob off there is an adjustment screw down in the shaft turn counterclock wise?? to lower setting. Good luck
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My oven won't reach temperature all the time. it
It is adjustable. Pull off the temperature knob behind it you will find the adjustment to raise or lower the temp. You will need an oven thermometer to test after you adjust.
Sep 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
WILL NOT CONTROL TEMPERATURE
there is some adjustment in the switch to control it but according to ur problem the switch is weak though if u adjust the switch it will work properly only for few days or few months instead u can change a new switch to fix the problem permanently
Jun 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
