Question about Sanyo DS25390 TV
SANYO TV AVM278 do not start. when you push key "power", you hear more than one time"click"( the sound of the 12v dc relay), and then the screen flashes certain times.sometimes it begins to work after the flashes, sometimes it does not . can some one who has the knowledge give me a hand because my kids are having a hard time when the tv does not work. thanks.
  • Sanyo Master
  • 19,396 Answers
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 17, 2009
Where do i find protect circuit of tv sanyo model ST-21KF2?
Posted on Feb 05, 2011
Flat Screen Sanyo Model DS27425, wont power up, you can hear the click like it wants to power up, but does not
your tv tries to power up but it does not because there is a relay which couples and decouples immediately. this could be caused by a defective flyback. replace the relay but if it remains the same replace the flyback. this will help you fix the problem
Sep 17, 2011 | Sanyo Televison & Video
I need the power cord for my tv and it says power (dc in 12v)
I would start by calling Sanyo and have them confirm what type of power cord you need. Most likely they will give you a free replacement or sell you one at minimal cost.
Give them a call at 619-661-1134
Sep 10, 2010 | Sanyo Vizon LCD-15A2 Television
Sanyo Vison model CLT2054 - three years old. Screen goes black shortly after turning it on. Is this a common problem? Is there an inexpensive fix?
clt2054 Sanyo vizon 20" TV
At power on my screen blinked on for a second, then went black for a minute or so, then blinked back on, this repeated. I noticed the external 12 volt dc 5 amp power supplys green light blinked on & off with the TV but it blinked off just before the TV did, indicateing that the problem was a power supply problem. Then I put the PS transformer up to my ear and could hear it buzz as it powered on each time. The buzz increased in frequency rapidly then stopped as the internal heat fuze/thermister er something, shut it off for a minute untill it reset. A person could buy a new Power Supply transformer for $14 to $40, or could try to fix their PS. But I simply hooked it up to a 12v car battery & the TV worked. On the back of the transformer is the pinout for the 12v 4 prong plug that goes into the TV. On the TV the bottom 2 pins a 12v+ & the top 2 pins are 12v negitive. Nails with the burrs filed off fit into the sockets, a strip of thin card board between the pos & neg nails for an insulator, & aligator clip jumpers on them to the battery got me a working TV. So I now know it was a power supply problem. I could follow the advice of others on this great FixYa site & try to fix my PS capacitor problem ? Or buy a new PS, or just put the TV in my 12v veggie oil diesel magic buss, er camper thingie. AND please don't send anyone $19.99 for free advice.
I hope this helps someone in somehow.
Dec 21, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Truck will not even crank over to start
Test for voltage at small wires on starter solenoid, by the stud on the starter, when someone trying to start. You should have power to it, or one of them, when key is cycled to start position, and none when you let go. If power there, my guess is your solenoid. May have to take starter off & bench test it. If no power to there, locate that relay you hear clicking,and check it, for constant power source going in, and one or more coming out when key cycled, which should be power source for wire at solenoid on starter.
Nov 22, 2008 | 1999 Dodge Durango
No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email
Nov 09, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP32746 Power Supply
Yes replace the power section of the tv.
Jul 13, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DS24425 TV Has No Picture and Very Faint Audio
Jan 09, 2008 | Sanyo DS24425 24" TV
Televison & Video Logo
375 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
