Sound ok , no picture no VS&.... volts
How can I fix power board?
    Problem Solver:
  • 15 Answers
First check caps, then diodes, then resistors, if it turns on your problem with no video indicates backlight(s) being burned out
Posted on Jan 24, 2009
60pa6500 LG Plasma NO sound or picture. Standby RED LED lit, when I hit power I hear a click and RED goes off. Checked caps on all boards visually and none are swollen.
Check capacitor with a digital volt meter. In my Samsung, the TV has a chip that check to see if all circuits are OK before turning on the set. Samsung has a power, input and video boards. The problem is when it check the high voltage circuit and it does not have 390 volts, the chip turn-off the power instead. (It is a safety thing.) You can buy a new power board or fix it yourself. The power board is where the 120 volts AC is plugged in, and near the 120 volts is small transformer, then you will see a capacitor rated 100 uf at 450 volts. Check for 390 volts here. If the voltage is less, then replace this capacitor with a 350 uf at 400 or at 450 volts.Samsung used a "small" capacitor when it should have ordered at large capacitor. Good luck.
Nov 28, 2017 | LG Televison & Video
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
Sep 21, 2015 | Samsung HP-R4272 42 in. Plasma HDTV
I HAVE A PROBLEM WITH A POWER SUPLY OF SAMSUNG PLASMA PS 51 E530 ALL VOLTAGE IS OK,5VOLT 12 VOLT IS OK,BUT VS AND VA VOLTAGE 0VOLT SO NO SCREEN,I CHECK POWER ON AND VS ON IS OK,can you help me
Sounds like it could be a bad capacitor on the power supply, or possibly on the video out circuit. Bad capacitors are a common problem in Plasma and LCD monitors and T.V.'s.
Jun 25, 2014 | Samsung 51 INCH PS51E530 Full HD Plasma...
SAMSUNG White line down center of tv ? UN55B7100WFXZA
The TV has a chip that check to see if the circuits are OK before turning on the set. Samsung has a power, input (control) and video boards. The problem is when it check the high voltage circuit and it does not have 390 volts, the chip turn-off the power instead. You can buy a new power board or fix it yourself. The power board is where the 120 volts AC is plugged in, and near the 120 volts is small transformer, then you will see a capacitor rated 100 uf at 450 volts. Check for 390 volts here. If the voltage is less, then replace this capacitor with a 350 uf at 400 or at 450 volts.Samsung used a "small" capacitor when it should have ordered at large capacitor. Good luck.
Nov 28, 2017 | Televison & Video
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a samsung l42v7 There is no picture. Sound okay
CHECK FOR ANY BACKLIGHTS, SOUNDS LIKE INVERTER BOARD OR POWER SUPPLY
Dec 30, 2009 | Televison & Video
NO PICTURE BUT I HAVE SOUND 42" INSIGNIA/PRIMA
I just repaired the TV.. It's the main power board that's causing the problem.The biggest board in the TV. I took a metre to the old board and it's failing on the VS circuit. I was only getting 14volts when i should of been getting 78 volts or something like that. If you look on aluminum backing of the screen .. top right corner there's a sticker which tells you what the voltages should be for the VS and a few others. It's the 10 pin socket top left corner on the main power board. VS is the first 2 pins. That's the part of the cuit that caused the screen not to light up. I had audio and power but no picture. All the other readings I took were normal on the board that was failing. Only the VS reading failed with the 14 volt reading. I put in another a good used main power board and took a reading from the VS pins and it was normal. I connect the cable to the y board and the TV powered up and is displays fine. If there's someone who does work on low level cuits and finds the actual part that is failing I would like to know. I replaced my board with a known good one and traced it too which part of the cuit failed. I suspect it's just buying time and don't plan on spending another $100.00 on another board after this one. So any help would be great. Thanks for all Craig
Oct 08, 2008 | Insignia 42" LCD Flat-Panel HDTV
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
