Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Owners manual for shop vac 6 hp 20 gal 52724-94
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
I have an old shop vac floormaster wet & dry vac, 8 gal., model 700c. I need the users manual to find out how to use it as a wet vac.
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Jul 04, 2011 | Vacuums
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
35 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
