Question about Singer 7462 Mechanical Sewing Machine
Even feed foot not feeding evenly
When I use the even feed foot for qulting, it bunches up as though I'm just using the regular foot. I purchased a new even feed foot, but the probem remains, so I'm sure it's the machine. It has worked fine in the past. Also, the reverse does not work. It just stitches in place when I hold down the reverse lever. The stitch width seems to be off just a little as well. I have to set it on 8 to get 12 stitches per inch. I recently had the gears replaced, everything worked fine until then. Oh, its a Singer 758 Touch and Sew.
Thanks, Amy
  • 65 Answers
Try going to
there is several help pages there, if they don't help I don't know whom can... LOL
actually singer has pretty good cust support and answer questions rapidly.
(after all they want us to keep buying their products!)
I hope this helps!
Good Luck and Happy sewing!
Posted on Jan 25, 2009
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
Why when I sew the fabrics not advance even if the claws are raised and the machine does not stop sewing. I have to close the switch
With the issues you are experiencing, it may be wise to take it for service.
Even though the feed dogs are raised, are they actually moving forward and back as you stitch (remove the thread, raise the presser foot, rotate the handwheel, and watch the feed dog action)? Check that the stitch length is set long enough that the feed dogs will be moving the fabric rather than sewing in place. Another thing to check is whether there is a pressure adjustment for the presser foot. If you are sewing light weight fabric, sometimes the pressure needs to be increased so the feed dogs are able to grab the fabric.
As for the machine running on, it could be a multitude of issues, ie the foot control, electrical... This may be something that a professional should evaluate.
Jun 22, 2016 | Janome Memory Craft 9000 Computerized...
Why does the top fabric come out longer when sewn?
Because there is more drag on the top than there is on the bottom, from the pressure foot.
There is a solution, however; Singer and many other companies offer an even feed foot that you can use place of your standard one. That foot offers the same teeth on the top that is already in the feed dogs, and it will even out the feed.
Your machine probably takes a low-shank foot--most modern machines do.
Feb 18, 2015 | Singer Sewing Machines
Installing generic even feed foot
higher up the foot bar you will find a clamp screw undo it reposition the foot then tighten it back up
Jan 01, 2014 | Sewing Machines
Why does the backing gather up even though it is penned and sprayed with quilting spray
Presser foot tension is to low for the weight/finish of the fabric, or bottom dogs are worn.
  • The feed dog feeds the fabric under the presser foot while you guide the fabric.
  • The feed dog regulates the stitch length by how much fabric passes under the presser foot as the machine stitches.
  • It is important for you to not push and pull the fabric under the presser foot. Allow the feed dog to move the fabric, so that you do not bend and break sewing machine needles.
Hope this helps.
Feb 09, 2011 | Sewing Machines
Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
May 29, 2010 | Juki TL-98Q
How does one attatch the fanome even feed foot to
It sounds like you may have the wrong even feed food. It should be a simple task to put on. the packaging on the foot should say its for Janome horizontal bobbin machines.
May 22, 2010 | Janome 8080 Computerized Sewing Machine
What instructions are there for a brother nx400 even-feed foot
Remove the screw holding the regular presser foot and the presser foot holder and set aside.
Place the take-up lever in the highest position.
Hold the even feed foot with your right hand with your thumb holding the lever of the foot in its highest position. Place the even feed foot on the presser bar and make sure that the lever of the foot rests upon the needle bar thumbscrew. While holding it in place, fasten the foot to the presser bar with the screw.
As the needle bar goes up and down, the lever on the even feed foot should rest on the needle bar needle serew and go up and down as well.
Jul 19, 2009 | Brother Sewing Machines
How do you fit and use a quilters foot
The 1600-DB requires a special Walking or Even Feed Foot due to the high sewing speed, so ensure that you have the correct foot, as the "normal" top loading machine foot will not fit.
I hope these images will assist in showing how the fitting should look.
This is the Normal - WRONG - foot to compare:
This is the CORRECT Foot:
From the Janome Accessories Guide:
"The even feed foot walks over fabric to assist with smooth feeding. Fabric can be sewn without puckering as the fabric is gripped and fed by both the upper and lower feed dogs. This foot has been specially designed for durability and to work at the high speeds of the 1600 series.
Part Number - 767-403-016"
If you need a larger image or you want any more help with this, just drop a line through the "Contact Us" page at
Apr 29, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Feed dog
It may need the feeddogs adjusted by a tech. We use a guage to measure the correct height. Even though visually it may look like they are moving ok they may be too low. You could use the top end of a needle and lay it alongside the feeddog at its highest point. It should be level. Also check the presser foot pressure. It may be set too high and not holding the fabric down. Good luck to you. Rick
Aug 05, 2006 | Bernina Virtuosa 160
Singer 7462 Mechanical Sewing Machine Logo
131 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
