Question about Baby Lock Ellure
Upper thread keeps breaking
I have a BabyLock Ellure. I won't sew many stitches (10-20) until the upper thread breaks. This is a new problem. It doesn't matter what brand of thread. I'm so frustrated!!!!
  • kent_atkins Jan 24, 2009
    I don't know how to check the timing, I have already cleaned the assembly.
    Brigadier General:
  • 8,619 Answers
Hi
After you rethread a broken upper looper thread, make sure the needle thread is on top of the thread plate before you start to serge again.
Check to see if your differential feed is on. If it is not supposed to be on set the differential at N.
Make sure the cutting blade is at the correct width setting.
Check upper and lower looper tension settings.
Make sure the machine is threaded properly and the threads are in the tension disks.
Posted on Jan 24, 2009
  • 350 Answers
I'm told you should check the tension button just above the needle first.
Hope this is helpful.
Good Luck!
  • Jack Iaria
    Jack Iaria Jan 24, 2009
    I tried calling them (12:40am EST Jan 24th, 2009) but their closed right now!
    I'd try calling them Toll-Free if you haven't already!
    BABY LOCK
    1-800-313-4110
    They have a huge website that might help you!
    Baby Lock Home Page @
    http://www.babylock.com/
    Or Contact them by EMAIL @
    http://www.babylock.com/contact-us/index...
    Hope this was helpful.
    Good Luck!
    Sergeant:
  • 378 Answers
Its the problem of the extra tension on the thread.u need to adjust the machine timer settings as well as clean the assembly and check that the inner belt gets only the required tension.
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Install a brand new needle.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Sewing Machine Thread Keeps Breaking
Why is my thread breaking
Sewing Machine Problem 1 Thread Breakage
Feb 11, 2016 | Brother Sewing Machines
I have a Quantum CXL Singer sewing machine and the thread keeps breaking. It will make about 3 stitches and breaks. It is breaking in the same place.
Make sure the thread coming off the spool is not wrapping around the spool spindle. Install a brand new needle. Remove ALL the thread from the machine. Clean bobbin area of any dust, lint, threads. Set upper tension to the midpoint. RAISE the presser foot and then totally re-thread the machine from beginning to end verifying the sequence is correct. Test.
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Oct 06, 2015 | Singer Sewing Machines
My thread keeps breaking after I sew just a little bit. I have changed thread, check it is put on correc. Please advise. Not sure if I have the top tension correct.
1. While threading put the foot up.
2. Give gentle tugs along the way. It should be without feeling any hangups.
3. Wherever the hangup is you must correct. Usually at the tension disc.
4 Sometimes the tension disc is tightening more than the indicator says. It should be about four. You can lower this tension setting until the stitch looks good.
5. You may have to take the tension assembly off and clean it thoroughly and sand any rusted spots.
May 30, 2015 | Sewing Machines
The top thread keeps shredding/ripping while trying to embroider. Using a babylock ellure.
as you thread the machine check for burrs, also on the needle plate
Feb 24, 2014 | Baby Lock Ellure
CONSTANT Check upper thread warning on a Babylock Ellure
try changing the needle
check for burrs on the needle plate and in the bobbin area
if the problem persists then the machine may have to be checked
again
Nov 26, 2012 | Baby Lock Ellure
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
Thread problem
I'm not sure which thread you are referring to, its either the bobbin thread (under) or the needle thread (above.top)
I'm sure you can find some helpful advise here on the baby lock site
http://www.babylock.com/support/faq/?FAQ=10
Jan 24, 2009 | Baby Lock Ellure
Thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Oct 20, 2008 | Toyota TL-432DE Mechanical Sewing Machine
BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Aug 26, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
190 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
