Question about Canon Speedlite 430EX TTL Flash
Canon speedlight 430EX II won't fire
It was working fine before.
But I tried to take some photographs today, and flash worked for the first five minutes, then it stopped working completely.
The red light won't even turned out.
Pressed pilot button, nothing happens.
I don't know what's wrong with it, did the light got burned out or something? I've had this flash for not even a year.
Help please
  • 2 more comments
  • bookophoto Mar 07, 2009
    exact same problem! its not the battery, I put fully charged batteries in and pilot light is illuminated. Its also not the camera to flash connection, because I cant even get the unit to test fire by pressing pilot when the unit is removed from the camera's flash mount. I read the trouble shooting in the manual and see no explanation for this. I too have had this flash for about a year. Is the bulb burned out?? Why does the manual not explain what happens if your bulb burns out?
  • Anonymous Mar 20, 2009
    I have the same problem.
    I put brand new batteries in it and still no luck.
    The red light is on. I press it and if I look at the flash itself I can see a very small glint of light but not a huge flash like it should be.
  • gailephotos Mar 27, 2009
    Just joining the crowd. I'm having the exact same issue with my Speedlite 430EX. Just changed batteries.. didn't fix it. Thank GOD it's still under warranty and I've got the paperwork. I'm sending mine for repairs.
  • Anonymous May 04, 2009
    Same problem. Flash is 2 months old!
The conceting piece of the Flash has cracked when i dropped it, is there any thing i can do to repair or exchange it?
Posted on Nov 03, 2009
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Dec 29, 2013 | Canon Speedlite 430EX TTL Flash
Speedlite 430EX II pilot red light wont turn off wont fire
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings in your camera menu settings.
Feb 13, 2013 | Canon Speedlite 430EX TTL Flash
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
Canon 430EX II flash... batteries A-OK. But flash doesn't fire... tried pilot... doesn't work
Hello
Thank you for using FixYa for your problem
Sounds like the flash tube has gone.
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Canon Speedlite 430EX TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
Canon 430EX Flash
I have a 430ex and S5, I don't think the zoom head will move without being mounted on a camera.
If the flash test fires ok, then it should be fine.
Oct 16, 2007 | Canon Speedlite 430EX TTL Flash
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Canon Speedlite 430EX TTL Flash Logo
2,210 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
