Question about Saeco Caffe Charisma Espresso Machine
Brewing unit stuck in a Saeco Charisima (Carrisima)
My Charisima brewing unit cannot be removed. I followed the instructions of Saeco and took out a Philips screw, however the unit is still stuck. I've called again Saeco and they said the machine has stopped in the middle of a cycle and the unit cannot be removed. Any suggestions?
mirran
  • 515 Answers
SOURCE: Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Posted on Aug 06, 2008
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
  • 1089 Answers
SOURCE: Brew Unit Stuck Seems to be in Mid Cycle
Remove the dredge drawer. Open the right side door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Posted on May 23, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
  • 80 Answers
SOURCE: cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Posted on Aug 30, 2009
I removed the brew group and it is now stuck in the remove position. I cannot replace it in the machine. The lever that says push is stuck in the pushed position
Hold brew unit in your hand like you are about to put it in the machine, you do not need to push lever to put unit in machine only when removing. Now turn unit 180 degrees notice little latch in top of square make sure it is down.
Jul 27, 2014 | Saeco Odea Go
Saeco incanto classic
http://www.partsguru.com/SaecoIncantoClassic.html
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
I have a saeco magic comfort. the brew unit is stuck. i took it to a repair shop who told me I need to spend 350 to repair it. not sure if there is something else I can do.
Hi
This is one of my tips on How to.
http://www.fixya.com/support/r2296982-removing_stuck_brew_group
once you get it out it may have broken the brew drive, and that is what they were talking about but maybe not. Follow my directions to see.
May 25, 2011 | Saeco Magic Comfort Plus Espresso Machine
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
Cleanded brew unit as instructed - brew unit miss error
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Jun 25, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco incanto deluxe gear or splinbe drive out 180 degrees.
Thats a tough one without seeing the unit, use the pic below to help align the unit.5101bd5.jpg
May 31, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Caffe Charisma Espresso Machine Logo
21 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
